coolant flush
Old Aug 29, 2013 | 04:01 PM
g tinsley's Avatar
g tinsley
coolant flush
I have a 2005 with 41000 miles no problems should I flush the coolant I have heard it might stop up the oil cooler thanks for your reply
Old Aug 29, 2013 | 05:10 PM
69cj's Avatar
69cj
Do you know what your ect/eot deltas are? If they're good I'd do a drain and refill. If they're out of range then I'd try the flush.
Old Aug 29, 2013 | 06:32 PM
diesel_dan's Avatar
diesel_dan
Take a look at the Tech Folder on doing a flush also. I'd suggest a coolant filter if you don't already have one. and try to drain/flush via the block drains if you can, a number of folks say the sand seems to "hide" there...
Interestingly mine was flushed maybe 500 miles ago and I had a slight leak on the coolant filter I installed just recently (my fault with not a tight wrap on the teflon tape on one fitting). I ended up draining a couple of gals out of my driver's side block drain, 1st to install the filter and again to fix my little leak. I had almost put all the fluid back in the second time and I look at the bottom of the container and guess what?! Casting sand... Not a lot, but enough to make me happy I just put on the filter...
DavidE
Jul 16, 2014 01:03 AM
Metalhead47
Jan 7, 2014 11:00 PM
PowerStrokeJoe
Jan 3, 2010 09:42 PM
indyraven
Nov 8, 2009 09:58 PM
FORDSDOWNER
Jun 26, 2008 07:39 PM
