Stock fan question
Old Aug 28, 2013 | 07:54 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Stock fan question
Looking at the parts CD, it shows all stock fans as either 4-blade or 5-blade (mostly later models). I'd swear I've seen a bunch of 6-blade fans? Only concerned with 48 - 52's.
Old Aug 28, 2013 | 08:10 PM
52 Merc's Avatar
52 Merc
I believe the bigger trucks had 6 blade fans. The engine I found to use in the Merc was from a a '51 F6 and had a 6 blade fan. Unfortunately, it was also KO'd to the point I wouldn't trust it.
Old Aug 28, 2013 | 08:34 PM
Doc's Avatar
Doc
Makes sense. Ross, do you remember the flathead I got from the guy who wanted to put a newer engine in his F-5? It has a six-blade fan. I don't know if it's stock or not.
Old Aug 28, 2013 | 08:56 PM
52 Merc's Avatar
52 Merc
I looked through my original 1955 parts catalog and it shows the same thing; 4 blade fans and 5 blade fans with the extra cooling option. No 6 blades listed. But we have to remember that the parts catalogs show replacement parts available at the time of printing. They're not assembly manuals or a bible of what parts came delivered from the factory. It wouldn't surprise me if a batch of 6 blade fans were used at assembly due to availability, but the replacement for it from the parts counter would have been a 5 blade.
Old Aug 28, 2013 | 09:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I knew I'd seen one somewhere!
Wayne, the F-3 I posted from a CL ad here has a 6-blade, I don't think it was just Big Jobs. That would make sense, although they also spin their engines a lot more for any given speed, so maybe wouldn't need more fan?
Old Aug 28, 2013 | 09:35 PM
tinman52's Avatar
tinman52
Welder User
I have a 6 blade on my pickup, works great. Every bigger truck (F-6) around here seems to have one.
The six blades are slightly larger diameter as well...
Old Aug 28, 2013 | 10:21 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You're talking about your F-1, right? I wonder if you got an F-1 with either of the HD trans options (3-sp HD or 4-sp spur) if the larger fan came as part of the package?
Old Aug 28, 2013 | 11:12 PM
tinman52's Avatar
tinman52
Welder User
Yes, my F-1. I don't remember if the truck had a 6 blade fan originally.....I used many parts from my "stash" as well.
Old Aug 28, 2013 | 11:57 PM
52 Merc's Avatar
52 Merc
Just to be clear I did say bigger trucks, as in larger than your typical pickup, not Big Jobs. Sorry for any confusion. As I mentioned, the guy I got my engine said it came from an F6, and it had the 6 blade fan just like yours shown. (Well, except for mine had bent blades. )
Old Sep 4, 2013 | 02:31 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Stumbling around the shop tonight this caught my eye. Hadn't paid it any attention, just a spare engine sitting out of the way. But it brought this thread back to memory. So I looked it up in the January, '54, edition of the Chassis Catalog. Part number 59T 8600-B, same 18.5" diameter as the four blade, and listed as "extra cooling" special equipment for all models that used the 239 from '48-'52. The six cylinder counterpart had five blades.
Then I looked in the 1964 reprint catalog, same as the CD I think, and it's not there. Further proof that it pays to have the old paper books as Chuck preached to me long ago. Stu
Old Sep 4, 2013 | 09:34 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Thanks Stu, good info!
Here's why I asked the question. My engine is a EAB Car engine, and uses the narrow belts. These use a completely different fan system, with a sealed cartridge bearing. The concept is that when the bearing wears out, you buy a whole new assembly; fan, spindle with sheave, and bracket. I've never seen one that is worn out but mine also has only 3 blades. Haven't had problems, but...
So I took a spare apart, and figured out that the bearing is. It's the same as a water pump bearing with a longer shaft. With a little adapting, I made one up that uses a Flex-A-Lite 6-blade universal 18.25" fan blade.
Old Sep 4, 2013 | 09:44 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
That's come along nicely since I saw it in pieces. Good job Ross!
Old Sep 4, 2013 | 09:49 AM
52 Merc's Avatar
52 Merc
That's very interesting, Stu. My old catalog is the November 1954 issue, and that fan was obsoleted at some point during that year. It's not listed in my catalog. I show two 4 blade fans and three 5 blades for 48-53 239 engines. No 6 blade fans at all.
Old Sep 4, 2013 | 10:02 AM
Doc's Avatar
Doc
The fan in Stu's picture is the same as the one on my engine pictured above (Ross crouching beside it). I bought it last summer, but didn't really "notice" the six-blade fan until Ross saw it in person and pointed it out. Very interesting. And that engine came directly from a "barn-find" 1952 F-5 in Minnesota that was purchased on ebay.
medctr1
May 11, 2016 12:26 AM
Gertie-The '49 F2
Oct 5, 2015 07:40 PM
Berg
Apr 16, 2011 11:10 AM
Powerstrokin_350
Flathead V8 & Flathead 6
Jun 18, 2009 07:28 AM
rcav8or
Jan 10, 2008 07:28 AM
