XD Spy wheels
Old Aug 28, 2013 | 07:50 PM
jackstrx's Avatar
jackstrx
XD Spy wheels
I bought a set of MT ATZ mounted on 17'' XD spy wheels for my Ford f250 diesel. Drove to work this morning and back home and the truck was all over the road. I got out and found that both front wheels had no wheel weights at all on them. It looked like the brake caliber had peeled the wheel weights right off. They were the stick-on weights and they were on there when I put the tires and wheels on the truck. Anyone ever have this problem? Is the brake caliber too close for stick-on weights?
Old Aug 28, 2013 | 10:45 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
On a 17" wheel, most likely.
Old Aug 29, 2013 | 05:38 PM
Joe_planet's Avatar
Joe_planet
so the smallest wheel you should be running on a 6.7 sd is a 18"
Old Aug 29, 2013 | 06:38 PM
BigF350's Avatar
BigF350
FTE Emeritus
Well, if you use external weights, you should be fine (or position your internal ones so they clear the caliper). But I know there isn't much clearance over 17" rims.
The XL models (and duallies) come with 17" wheels.
Old Aug 30, 2013 | 12:55 PM
Firekite's Avatar
Firekite
What year is your truck? Can you post a pic of the inside of the wheel as well as the gap between the caliper and the wheel?
What would bother me about that is that it sounds like the wheel is deflecting under load. Running no weights at all should only result in an unbalanced tire, not wandering all over the road. I'm assuming these wheels are lug centric, not hub centric? Their site XD Spy Wheels lists none of the relevant info like that, nor even the load rating of these wheels. I would not run them on a Super Duty.
Old Aug 30, 2013 | 07:38 PM
BigF350's Avatar
BigF350
FTE Emeritus
All SD wheels are lug centric.
Old Aug 30, 2013 | 09:18 PM
Firekite's Avatar
Firekite
No. Factory wheels are hub centric. Notice how the factory lug nuts are like little top-hats, simply pressing the wheel against the hub, rather than little cones seating deep into the wheel around the lug?
Here, watch this:
Old Aug 30, 2013 | 09:40 PM
m-chan68's Avatar
m-chan68
Here, watch this:WHEELS AND SPACERS - YouTube
First off, that guy in the video should rename is website to powerstrokehurt.com because he is nothing more than a glorified salesperson spewing tons of misinformation on a lot of matters pertaining to Powerstrokes, but that's another story.
As far as using wheel spacers are concerned, I personally consider it to be a BIG no-no. In some regions, using them will fail you on a safety inspection. I for one, would not put my signature on one. And here's why. By increasing the offset of the wheel, you place more stress on the axle’s studs, and in a front axle application on the unit bearings (or spindles) and ball joints of the axle. You also increase the tire scrub radius, changing the way the vehicle handles and increasing the difficulty of slow-speed turning. Also, by adding wheel spacers you are adding more components, and the more components, the more potential for failure.
Old Aug 31, 2013 | 02:05 AM
Firekite's Avatar
Firekite
We're not talking about wheel spacers, just some tangential education on what it means to be hub centric or lug centric. When a manufacturer hides their load ratings, that's a clue. Stay away.
That said, what exactly is the "axle stud" you reference? Do you mean a wheel studs, what the lug nuts bolt to? If so, that's not a major concern, since with proper wheels and spacers, they're not lug centric. The lug nuts are only holding the wheel/spacer against the mounting surface. The weight and force are being taken by the hub itself, which is why hub centric is a great thing for Super Duty trucks. It's true that the further outboard the centerline of the wheel, the more leverage there is to exert on hubs and steering components, but that's true of any oversized tire application. It doesn't really matter a whole lot whether that is achieved through lower backspacing on the wheel or with the shallow OEM wheels with spacers. I'll be honest, if I were forced to do one or the other, I'd much rather have hub centric wheels on hub centric spacers than some aftermarket lug-centric fashion wheel.
Old Aug 31, 2013 | 03:17 PM
BigF350's Avatar
BigF350
FTE Emeritus
Sorry, I meant aftermarket wheels. Factory ones are hub centric - I have never seen aftermarket wheels that are hub centric.
Old Sep 2, 2013 | 02:10 AM
Firekite's Avatar
Firekite
Weld wheels were. I think some of the Mickey Thompson classics are, too. Otherwise, there's always figment rings.
RenoHuskerDu
15
May 27, 2025 09:18 AM
ComputerCowboy
Jan 23, 2012 09:31 AM
mpuvdd
Aug 18, 2009 12:33 AM
Holmesuser01
Appearance & Dress-Up
May 24, 2005 09:51 AM
STJones
2004 - 2008 F150
Sep 26, 2004 01:08 PM
