Part numbers?
Old Jun 13, 2015 | 11:31 AM
427ford's Avatar
427ford
Looking for the part number for the fuel line fitting that screws into the FP regulator cover. Anyone??
Old Jun 13, 2015 | 01:01 PM
87crewdually's Avatar
87crewdually
This looks like it according to the diagram in this listing.
http://pages.ebay.com/link/?nav=item...556378&alt=web
Ford #: 3C3Z9N320BA
Old Jun 13, 2015 | 04:47 PM
Yahiko's Avatar
Yahiko
Originally Posted by jswartz84
Sean cleaned up that list and put it in a pdf us. Here is the link.
http://www.washingtonspeaksout.org/D...0list%2001.pdf
Hmm looks like I may of moved that PDF so not I have to go find it and repost
for the people that need it.
Sean
EDIT : I got into my web-hosting account and found that all the files have
been removed. I need to contact them and see what happened. I have not
been able to find the file here on my computer also. So if anyone has a copy
PLEASE let me know and I'll get it from you and repost it.
Sean
Old Jun 14, 2015 | 08:13 AM
427ford's Avatar
427ford
I looked around a bit more. Looks like this may be the one that screws into the 'blue spring' cover..... 3C3Z9N320AA Ford's diagrams aren't real helpful.
One shows M16 (3C3Z9N320AA) thread and the other M12 (3C3Z9N320BA).
Old Jun 17, 2015 | 09:04 AM
nathan66669's Avatar
nathan66669
6C3Z-9C995-A /---------Injector hold down 20MM DOWEL (Late 06/07 heads)
Old Jun 17, 2015 | 10:05 AM
nathan66669
If this is the same for the 6.0L van:
2007 Ford E-350 Super Duty Fuel Tube Banjo Washer | FordParts.com
your looking for the adapter that connects into the regulator and adapts to the metal line PN 9N320B
ford # 3C3Z-9N320-BA
3C3Z-9N320-BA - Ford Parts Giant
It helps me to use the fordparts.com site with VIN number and search for the drawing and 'callout' name then fo to that fordpartsgiant site and find the order number based on the callout name.
Also, noticed the master list only has the 6.4L banjo fuel bolts and washers. Heres the 6.0L banjo (one per side) + crush washer (2 needed per side):
3C3Z-9A375-AA (Washer - Callout Name: HW1) Gasket 15MM
W301866 (Callout Name: HM1) Kit - Hardware 12MM, Check Valve, Banjo Bolt
The bolt looks obsolete, not sure if theres an updated PN
The crush washers for the fuel supply into the filter housing banjo bolt are:
F6TZ-9160-AA (GASKET - FILTER BOWL - Callout Name: 9160 )Gasket - Filter Bowl 19MM, Banjo Washer
I know its an older post, but awesome info here!
bismic
Oct 26, 2023 06:22 PM
Piolet
Jun 25, 2012 08:54 PM
m-chan68
May 6, 2012 03:51 PM
My4x4Toy
Oct 5, 2004 05:59 PM
emtabmm
Jan 1, 2004 08:25 PM
