PLEASE HELLP
Old Aug 26, 2013 | 06:01 PM
thumper1976's Avatar
thumper1976
PLEASE HELLP
I have a 93 F250 I am converting it to a B&M floor shifter. The transmission id tag is missing how else can I tell what transmission type it has I can say it has a 351W in it for a motor. Please help if you can.
Old Aug 26, 2013 | 06:08 PM
Conanski's Avatar
Conanski
It's an auto so does it have 4 forward gears or 3? If 4 then it's the E4OD if 3 it's a C6.
Old Aug 26, 2013 | 07:27 PM
dixie460's Avatar
dixie460
Correct me if I'm wrong but ain't it possible he could have the 4R70W also?
Count how many bolts are in the transmission pan:
E4OD has 20 pan bolts.
4R70W has 14 pan bolts.
C6 has 17 pan bolts.
EDIT: also if you have an Overdrive button on the end of the gearshift, you do NOT have a C6. It's either a E4OD or 4R70W.
Old Aug 26, 2013 | 08:49 PM
rla2005's Avatar
rla2005
The F250/350 trucks were never equipped with the 4R70W or older AOD transmission. C6 3-speed or E4OD 4-speed automatics.
Old Aug 26, 2013 | 10:12 PM
88PONY's Avatar
88PONY
look at the door tag there should be sticker look at the "TR" code that's the trans code...google it...if not call the dealer and give them the vin#
92 Red Flareside
40
Jan 24, 2026 12:15 PM
jsgoss02
29
May 20, 2025 10:20 AM
windyhill
26
Nov 13, 2010 06:20 PM
76f250highboys
Apr 5, 2010 05:53 PM
dezracer
Jan 21, 2005 07:42 PM
