Porting, chamber work questions
Old Aug 25, 2013 | 11:45 AM
F-250 restorer's Avatar
F-250 restorer
This engine has been a learning session for me. I knew nothing about head work or porting when I began it and paid $300 to have the bowls cleaned up and the runners gasket matched. At that time I also had larger valves installed.
At that time I was told there were ridges in the chambers that shrouded the valves. These are Ford's quick burn system, I have learned. Now I want to remove the ridges to increase flow, allowing the cam (valve lift) and larger valves to work as they should, allowing max flow. I'm also going to clean up the runners and polish the chambers.
I have photos to guide me, but was hoping to get some advice/guidance here. I'm posting a photo below of the ridges. Thanks in advance. k
(I know that in the photo above there appears to be a crack between the valves, but it is not a crack.) Below is a 300 chamber w/o the ridges (kindly disregard the different shape chambers, one kidney bean shape, one normal shape):
I guess what I am wondering is should I have this done by a pro. It seems that in the kidney bean shaped chamber there is a 'wall' where the chamber meets the gasket mounting surface, almost 90* to the mounting surface. Should I try to duplicate that, or am I simply trying to deshroud by creating a .125-.250 groove of free space around the valves where the ridges are, and then reduce the height of the ridge a bit.
How does one control, standardize, make sure each chamber is the same volume?
Old Aug 25, 2013 | 12:31 PM
keiths78f150's Avatar
keiths78f150
In short, yea I would have it done by a pro.
Old Aug 25, 2013 | 11:05 PM
HIO Silver's Avatar
HIO Silver
If you are asking this question, then yeah... better to have it done by a pro.
BUT for your education, cleaning up the chambers should have been done prior to or with the port work and before the valves were installed. Typically, old valves are inserted to reduce the chance of nicking the seats with a carbide burr and rolled cloths.
Cylinder head volume is done my measuring its displacement using a burrette, colored alcohol, a plexiglass plate, and a graduated cylinder (a scientific beaker). The methodology is too long to write up so take a ride over to YouTube.
Dobies4life
Oct 28, 2013 09:43 AM
F-250 restorer
Feb 17, 2013 08:52 AM
fordboy300
Jan 14, 2013 12:29 PM
F-250 restorer
Nov 5, 2010 07:51 AM
terilynn
Mar 14, 2005 01:22 PM
