Code help needed
Old Aug 24, 2013 | 08:50 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
Code help needed
Need some decoding help, on My '78 F150 Super Cab:
rear axle: 16
front axle :A
Paint code: UP
Also,did the Super Cab VIN's start with X?,
Thanks
Old Aug 24, 2013 | 09:15 PM
ranger429's Avatar
ranger429
I've got the book for 79 but I'm thinking this should be the same.
Rear axle, 9" ford with 3.50 gears, 3750#
Front axle should be a D44
Paint,
U, pastel sand
P, coral
Yes all supercabs started with X, yours should be X26
Old Aug 24, 2013 | 10:01 PM
78 & 87 Super Cab
Paint,
U, pastel sand
P, coral
Thanks for the help! Mine starts with X14
Old Aug 24, 2013 | 10:10 PM
ranger429's Avatar
ranger429
X14 is correct. For some reason I was thinking 250 VIN.
Are those the correct colors?
Old Aug 24, 2013 | 10:11 PM
mikeo0o0o0's Avatar
mikeo0o0o0
X14 is correct for an F150 4WD supercab. X26 would be an F250 version
Axle 16A=(16) Ford 9" non-locking, 3.50 ratio, 3,750 lb capacity (A) adjustable steering column w/ power steering.
Ford rarely put any actual front axle info on the warranty plate with exception of the "infamous" P code.
Old Aug 24, 2013 | 10:21 PM
78 & 87 Super Cab
So I should look on the front axle for it's code?
By adjustable column, do you mean tilt column?
And yes ranger 429, those colors sound right
Old Aug 24, 2013 | 10:33 PM
mikeo0o0o0's Avatar
mikeo0o0o0
There used to be a metal tag held on by one of the diff cover bolts. Whether or not its still there is the question.
And yes, Ford called their tilt column adjustable. The release for it is the turn signal stalk, push forward on it to release the tilt.
Old Aug 24, 2013 | 10:44 PM
78 & 87 Super Cab
Ok, thank for the info
packnrat
Oct 3, 2009 10:31 PM
Ranger GT2
Jun 19, 2007 02:41 PM
cbfomoco
Jan 28, 2006 04:24 AM
MustangGT221
Aug 28, 2002 07:41 AM
74F250
May 4, 2002 06:58 PM
