using autoengineuity to check injectors
Old Sep 5, 2006 | 04:57 PM
mtgrzlyman's Avatar
mtgrzlyman
can this be done and if so how do i do it? thanks.
Old Sep 5, 2006 | 06:05 PM
Green_Dually's Avatar
Green_Dually
do the buzz test.
Old Sep 5, 2006 | 06:40 PM
1997F-350's Avatar
1997F-350
buzz test checks the wiring and the solenoids to make sure they are working. do that first. if you hear the idm buzz and then 8 buzz's that part is good.
then for the actual injector do a cylinder contribution test. make sure the eot temp is above 160* the closer to 200* the better. the pcm wont let you run the test with it lower than 160*.
dont do anything with the truck while its running doing the test. just let it do its thing. its scary the first go around.
buzz test done with engine off.
cyl cont done with engine running.
Old Sep 5, 2006 | 06:55 PM
Uzumati's Avatar
Uzumati
Also you can monitor the "Rotational Velocity Change %" in live data to "Watch it" during a test drive
Old Sep 5, 2006 | 07:07 PM
1997F-350's Avatar
1997F-350
i knew i should of bought ae instead of ease.
Old Sep 5, 2006 | 09:40 PM
sgrol's Avatar
sgrol
What makes it scary? Just curious.
Old Sep 5, 2006 | 11:32 PM
1997F-350's Avatar
1997F-350
well the buzz test scared me didnt know what to expect.
and the cyl cont test just doesnt sound good. but you will get used to it.
Old Sep 5, 2006 | 11:34 PM
jtharvey's Avatar
jtharvey
What exactly are you watching here? I'm still learning my AE software, but plan to mess with it for a while on Thursday.
Old Sep 6, 2006 | 07:03 AM
Uzumati's Avatar
Uzumati
On the live data screen in the drop down there is a selection for "Rotational Velocity Change Cylinder X" X being the cylinder number. It gives you the live data the CCT uses during a contribution test.
Also during a CCT there should be no noticable difference in the sound of the motor (that is from the Service manual) But the KOER will make alot of strange noises
Old Sep 6, 2006 | 09:23 AM
jtharvey's Avatar
jtharvey
Thanks alan. Looks like I've got some observing to do. Do you know what kind of nubers I should be looking for or watching out for in the roataional velocity display? If it's similar to others I've seen, it's like a golf score, the higher the number the worse off you are.
Old Sep 6, 2006 | 09:33 AM
westpsd's Avatar
westpsd
ideally, the numbers would be all 0's, but I think acceptable is anything under 5%. If you have any one or two that read different than the rest, then you might consider checking out those cylinders for issues. If your truck is running fine, then I suspect you will not see anything larger than 2's. I ran my truck last week and had #8 showing up to 3.4% at idle, but as soon as I picked up RPM, all 8 cylinders went to 0. IT WAS A GOOD THING!
Old Sep 6, 2006 | 12:26 PM
Uzumati's Avatar
Uzumati
CCT will fail a cylinder if it is over 4% i believe the live data on mine stays below 0.6%.
Unless you have a real bad problem the Change should go to 0.0 with throttle but also the change will normally be at its highest when coming back to idle and then stabilize. Its the stabilized idle numbers that mean the most.
Another thing fun to watch is how fast the ICP responds to throttle and how the IPR resonds to the ICP
Old Sep 6, 2006 | 01:58 PM
Cuda_jim's Avatar
Cuda_jim
That's it! I can't stand it any more. I was waiting for the $$, but...but...
someone explain this to the other half for me
I'm off to buy a Autoenginuity right now.
Old Sep 6, 2006 | 06:47 PM
sgrol's Avatar
sgrol
me too, I can't take it any more!
Old Sep 6, 2006 | 06:49 PM
sgrol's Avatar
sgrol
Wait a minute. Do you guys work for Autoenginuity? Ah, what the h#ll, I'm getting one anyway.
