Duraspark - DurasparkII
Old Aug 22, 2013 | 11:56 AM
maverick600's Avatar
maverick600
I am swapping engines in my truck.....the one I am taking out is a 76. The dizzy has the smaller cap and the electronic box does have the blue grommet under it. The donor engine is out of a 79 truck. The dizzy in it has the bigger cap and also has the blue grommet on the electronic box. My question is what are the differences between the distributor itself and the boxes. Visually the distributors look the same and my understanding is that the duraspark II is a better ignition system but I am not noticing the differences, as you can tell i am a little ignorant to this.
Any help would be appreciated.
Old Aug 22, 2013 | 04:39 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Distributor is the same. Either cap works using the plastic adapter for the large style. Blue strain relief is a DSII.
Old Aug 23, 2013 | 04:48 AM
Col Flashman's Avatar
Col Flashman
Avoid the Duraspark distribs like the Plague.
They have caused me nothing but problems & costing me thousands in repairs.
The first time the cage that supports the electronics under the cap warped & broke, then the Shaft on the replacement snapped.
Causing major timing issues w/ massive backfires, bent push rods & valves on both occasions.
Go w/ a Mallory Distrib or a drop in E.I. such as a Pertronix.
TheKirbyMan
16
Jan 11, 2013 10:39 PM
jfw432
Mar 27, 2011 07:53 PM
Goose_52
Apr 14, 2008 04:11 PM
Woodsman_30350
Jun 22, 2004 09:15 AM
GregCS
Jul 5, 2000 09:52 PM
