Block casting numbers
Old Aug 22, 2013 | 10:25 AM
karjunkie's Avatar
karjunkie
Question Block casting numbers
Hi fellas, its been a lil while since ibeen on FTE, and i am making some progress on my 74, i have a 390 that the truck came with and was wondering bouts the year of this motor, the casting is C7 ME A, any help wud b appreciated, I wud show her off but cant get pictures to load
Old Aug 22, 2013 | 10:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Casting numbers are foundry marks, cannot be cross referenced to Ford part numbers.
Casting numbers on FE engines are WORTHLESS for identifying what the engine sizes are or what they were installed in...since all FE engines were cast as 352's.
All I can tell you is: C7ME is related to 1967. There will be a date code cast on the block, but this, when decoded, refers to the day the block was cast, not the day the completed engine was installed.
Old Aug 22, 2013 | 11:34 AM
karjunkie's Avatar
karjunkie
Thanks NumberDummy for confirming my thoughts bout it being a 67ish
Old Aug 22, 2013 | 12:09 PM
montana_highboy's Avatar
montana_highboy
Look for the casting date code on the oil filter mounting pad...
These blocks generally found their way into a vehicle 3-6 months after casting.
Old Aug 22, 2013 | 02:59 PM
karjunkie's Avatar
karjunkie
regarding #s
Thanks Montana, i was wondering what those were for, but unfortunately only a third of the date code is there, looks as if ford went to mill the oil filter hanger pad and two thirds of the date code gots ground away
72rtchallenger
Nov 19, 2017 05:19 PM
Fish_Scientist
Nov 21, 2010 04:35 PM
Richards73
Sep 3, 2010 06:54 PM
ford784x4
Sep 10, 2006 08:52 PM
Bob Crain
Sep 29, 2005 05:36 PM
