Sponsored by: Real Truck
**Update** Neutral safety switch didn't fix the problem
Old Aug 25, 2013 | 08:14 AM
Coastie6's Avatar
Coastie6
Mark is correct access the torx bolts from below the steering column. Here's a link to my original post on this subject. Another user posted a great photo of them in it: https://www.ford-trucks.com/forums/1...ml#post9799019
Old Aug 25, 2013 | 08:29 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by bthr22
If tightening those torx bolts isn't the solution, I'll try the cable and go from there.
If the bolts don't fix it I think it's time to check the wiring to the TRS. I know you think you did, but you didn't do anything useful. A visual check will only find the most obvious problem. You need to check each circuit for continuity, short to power, and short to ground. Anything less is just wasting time.
Old Aug 25, 2013 | 08:50 AM
bthr22's Avatar
bthr22
Mark, could you describe that process? Should I set my multimeter to Ohms? Where should I actually test? I wasn't able to check on the connector last night, as the probes are too large to fit into the connector.
It was later in the evening when I had the chance to check and getting dark, so I figured I'd rule out any obvious problems in the wiring before I spent a bunch of time troubleshooting.
Old Aug 25, 2013 | 09:30 AM
Mark Kovalsky
Yes, set your meter to ohms. With a wiring diagram find where the wires go. Read the continuity from one end to the other. Check for continuity to both ground and power.
NEVER put probes into the end of the connector! That will open the pins and create new problems that didn't exist before. ALWAYS probe from the end where the wires enter the connector.
Old Aug 25, 2013 | 09:55 AM
bthr22's Avatar
bthr22
Thanks for the info Mark! I'll check that out today if those torx bolts aren't the solution.
Old Aug 25, 2013 | 12:36 PM
bthr22's Avatar
bthr22
I looked, and those bolts were both very loose. One was almost falling out, so I tightened them and the truck fired right up. Tried it several times with no problem. So that must be the fix! Thanks for all the help!!
Old Aug 25, 2013 | 03:12 PM
Coastie6's Avatar
Coastie6
SWEET! Love it when that happens!
Old Aug 25, 2013 | 05:23 PM
projectSHO89's Avatar
projectSHO89
Yeah, that's usually how it works.
banoness
Feb 21, 2018 11:32 AM
Zelus
Feb 18, 2012 01:44 PM
blueovalboy_69
Oct 2, 2006 05:26 PM
jesseh
Dec 4, 2003 12:20 PM
