HELP!!!! 7.3
Old Aug 22, 2013 | 05:51 AM
bfo1djh's Avatar
bfo1djh
HELP!!!! 7.3
I am having a problem with my 2000 f-350 dually, it idles fine but if I dont let it warm up for 15 to 20 min , it will make it a 1/4 mile shutter, lose power and stall, then its hard to restart, when it finally dose start a lot of smoke then runs fine for the rest of the day. any ideas?
Old Aug 22, 2013 | 08:35 AM
JOHN2001's Avatar
JOHN2001
What color smoke are you talking about after the restart?
Old Aug 22, 2013 | 08:37 AM
bfo1djh's Avatar
bfo1djh
blueish its fuel i can smell it, only lasts a few seconds
Old Aug 22, 2013 | 11:18 AM
JOHN2001's Avatar
JOHN2001
Blueish is usually a sign of injectors. White is unburnt fuel. Black is obviously over fueled
Old Aug 22, 2013 | 11:48 AM
bfo1djh's Avatar
bfo1djh
can it be bad oil in the injector res? i read some stuff on how people never relize to change it and it causes driveability problem, i have 278,000 on it and have had it since april
Old Aug 22, 2013 | 12:35 PM
JOHN2001's Avatar
JOHN2001
I was hoping by now someone more knowledgeable than me on this topic would chime in.
I doubt that's the problem. I also assume your talking about the hpo ?resavor? (Bad spelling). Oil flows threw that so quick that it "shouldn't" have time to build up, then again there are a couple guys who swear to do because they have found a lot of junk in theirs.
Old Aug 22, 2013 | 05:21 PM
fordpride's Avatar
fordpride
Can you get it on a scanner and see what EOT is doing ?
Old Aug 22, 2013 | 09:58 PM
carltonwebb's Avatar
carltonwebb
90% of the time when these trucks do what you described, they are about 2 gallons low on oil.
Old Aug 23, 2013 | 01:01 PM
Brother Les's Avatar
Brother Les
.....only happened to me once... ....
so far
check you oil level.
millerfordidi
Nov 23, 2011 12:55 PM
diamondwsr
Nov 21, 2011 04:26 PM
bigk_54
17
Jul 31, 2010 08:45 PM
JudgeRC
23
Mar 27, 2009 07:51 PM
Butch(OH)
May 19, 2007 08:43 AM
