White smoke start up
Old Aug 21, 2013 | 10:45 PM
Triplespeed's Avatar
Triplespeed
Ok I have 97 f 250 EC it has a dp and a ww, ts 6 chip, new lift pump. I have checked all gp and they ohm 1.6 on all of them the GPR reads on both post 11.6 just replace all orings on injectors. I was told the injectors are oversized but I have no idea for sure.
On start it blows white for about 2 min until it warms up a bit. The exhaust smells like fuel when cold. Once it warms up truck runs great Lot of power fun to drive. The person I got it from said the whole time he ha it it blew white smoke he replace all gp and the GPR I'm no kinda at a loss as to we're to look next.
Old Aug 21, 2013 | 10:48 PM
ReBilld's Avatar
ReBilld
How many miles on the truck?
Old Aug 21, 2013 | 10:49 PM
Triplespeed
127000 not many miles the injectors were replace at about 115000
Old Aug 21, 2013 | 10:52 PM
Triplespeed
It is also an auto Trans.
Old Aug 21, 2013 | 10:56 PM
ReBilld's Avatar
ReBilld
That's real good miles. Compression should be good.
Old Aug 24, 2013 | 12:56 PM
Triplespeed
Just tested the volts going to the glow plugs from the harness on the driver side I'm only getting 7 and on the pass side I'm getting 10.5 to the plugs the relay says 11.6 on both post is that normal
Old Aug 24, 2013 | 05:07 PM
ReBilld's Avatar
ReBilld
Yeah, 11.6 on both posts is good. Check the wire going from the relay to the engine harness over to the pass. side. You may have to pull some of the loom off the harness.
Old Aug 24, 2013 | 06:42 PM
fordpride's Avatar
fordpride
1.6 on the GP's is right at the border line. New ones ohm around .5
I'd put GP's in it.
polky
Nov 7, 2012 06:41 AM
matowns21
161
Jul 22, 2012 10:11 AM
sassydog
General Diesel Discussion
Nov 22, 2007 10:03 AM
bdonaldson
Sep 28, 2006 12:29 PM
ziffle
Jun 28, 2006 09:51 PM
