door glass?
Old Aug 21, 2013 | 09:43 PM
havi's Avatar
havi
I'll have the Roast Duck
door glass?
Quick question, hoping for a quick answer. Is the door glass on the '57-60 flat glass? or is there a curve?
Old Aug 21, 2013 | 09:52 PM
hiball3985's Avatar
hiball3985
simple answer, Flat
Old Aug 21, 2013 | 10:17 PM
havi's Avatar
havi
thanks a bunch!
Old Aug 22, 2013 | 04:18 AM
oldebrush's Avatar
oldebrush
door glass?
Yep Havi, the only glass with a curve of any kind is the windshield. Everything else can be purchased from your local glass shop. You will want a fitted working pattern for them to cut and grind to.
1/4" thick is what you want.
Aloha
Old Aug 23, 2013 | 03:24 AM
randowe's Avatar
randowe
door glass
FLAT.... AS A FLITTER
Old Aug 27, 2013 | 01:34 PM
truckpastor's Avatar
truckpastor
Good to know...mine are all cracking and I never thought about having a glass co just cut me some
Old Aug 29, 2013 | 01:17 AM
oldebrush's Avatar
oldebrush
door glass?
I stated in my post that "1/4" thick" was what was wanted. I need to clarify that by adding that it needs to be 1/4" thick "Laminated Safety Plate glass"
That comes in clear, and tinted.
Hope this helps also.
Aloha, Tony
Old Aug 29, 2013 | 04:55 PM
randowe's Avatar
randowe
Thumbs up Vent window glass
Check out my post "vent window rubber". 'could save you some big bucks...
Old Aug 29, 2013 | 08:17 PM
Choptopjimmy's Avatar
Choptopjimmy
Aloha
This statement isn't totally true. The Custom Cabs have the wrap around big back window that definitely isn't flat too.
Jim
Old Aug 30, 2013 | 02:55 AM
oldebrush's Avatar
oldebrush
door glass?
Oh my, I guess I have to apologize. I totally forgot about that beautiful big back window option, which was indeed not flat. I am not sure if it was curved laminated, like a windshield, or if they were tempered. Never got the opportunity to see one out of the rubber gasket.
But, not all "Custom Cabs" came with the big window. Mine has a regular small flat glass.
Thanks for the correction Jimmy.
Aloha,
riggz
General Automotive Discussion
Apr 30, 2007 05:14 PM
low53
Feb 20, 2007 09:14 PM
slouis1948
Nov 29, 2004 02:37 PM
daveg66
Sep 2, 2003 01:45 PM
mikecroskrey
Sep 17, 2002 07:46 PM
