C6 converter plug?
Old Aug 21, 2013 | 08:19 AM
Corpsman24's Avatar
Corpsman24
C6 converter plug?
I am currently replacing the tranny pan gasket and tranny filter. While I was at it I thought maybe I would try my hand at draining the converter. I have never done this before. So I removed the inspection cover and bumped the starter a little till I saw thiss
The pretty blue bolt is a 7/16 th . My question is :
Is this the drain plug?
How much do I expect to come out...if it is full?
Of course I have exhaust pipe that dips just below this, so this should add to the mess. Thanks for any help.
Old Aug 21, 2013 | 08:56 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Yup, that's the converter drain plug, there should be another one 180 degrees away.
It can get messy if your drain pan isn't big.
As I recall, the C6 holds about 14 quarts total. Not sure how much is pan or torque converter.
Old Aug 21, 2013 | 09:36 AM
Corpsman24's Avatar
Corpsman24
I am assuming ( yikes ) that I only have to open one to drain the converter......?
Thanks again
Old Aug 21, 2013 | 10:10 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
As I recall, the C6 holds 17 quarts total. Not sure how much is pan or torque converter.
Old Aug 21, 2013 | 11:23 PM
myoldfords's Avatar
myoldfords
Thanks again
Yes, make sure you have a pan large enough for the capacity of the trans. You'll probably get 4-5 qts from the pan and the rest from the converter.
V10man
Jun 2, 2013 04:55 PM
05ExcursionLTD
Jun 19, 2009 07:15 AM
rusty9cab
Jun 10, 2009 03:45 AM
Point Blank
Jun 28, 2005 08:01 AM
eandaauto
Jun 11, 2004 11:01 PM
