courious
Old Aug 21, 2013 | 06:37 AM
broketruckjohn's Avatar
broketruckjohn
courious
i have a 92 f150 xlt lariat 6 cyl died put in 92 302 .40 over pistons edelbrock dual plane intake edelbrock 650 carb accel high energy ing mallory points dist shorty headders roller cam any ideas on comp ratio and appx h/p also has summit 1790 cam [whole kit lifters double roller gears ]
Old Aug 21, 2013 | 07:50 AM
Conanski's Avatar
Conanski
Hope you didn't use roller lifters with that flat tappet cam.
With stock heads it'll never make more than about 275-280hp.
Old Aug 22, 2013 | 01:06 PM
broketruckjohn
no the cam and lifters came as a set.the truck is pertty much stock,axles 5 spd.truck is daily driver and work truck just wanted a little more grunt out of it
Old Aug 22, 2013 | 03:34 PM
baddad457's Avatar
baddad457
Comp ratio could be anywhere from 7 to 1 to 9.5 to 1, depending on what pistons were used and what heads are on it. HP is any ones guess.
Old Aug 24, 2013 | 06:26 PM
broketruckjohn
i have a pair of 351-C heads 2-V think there early 70s would they work on my 302 and will it make any difference
Old Aug 24, 2013 | 10:23 PM
85e150's Avatar
85e150
They will not work without modification, and it won't make any difference.
dimora
176
Apr 26, 2018 08:00 PM
TheSilverBullet
Mar 11, 2010 07:43 PM
1966Tbird
Aug 11, 2009 04:39 PM
roger dowty
18
Oct 24, 2005 07:38 AM
scott9320
Mar 25, 2003 10:25 PM
