Opinions on My New Engine 306ci
Old 08-10-2009, 11:53 AM
1966Tbird's Avatar
1966Tbird
1966Tbird is offline
1966Tbird is starting off with a positive reputation.
well i would like to know if anyone has any suggestions on my new combo for my truck
.030 over 302 roller block
300 intake/ 310 exhaust adv. duration, duration @ .050 of 224 intake and 234 exhaust, Valve lift of .496 intake and .520 exhaust, Lobe C/L is 112
(cam is a hydrolic cam non roller because i don't have the funds for a roller cam and this cam is already in my truck)
iron gt-40 heads that have been lightly ported with bigger valves
edelbrock rpm airgap intake manifold
dss main girdle
forged pistons around 9.5-10:1 compression
stock rods (reconditioned)
stock crank (reconditioned)
570 holley vac. secondary
125 shot of nitrous
headers+2.25in dual exhaust
1.6:1 roller rockers
hei dissy with mallory coil and accell internals frpp plug wires
personally i think the cam should be a solid cam or a hydro roller cam of similar specs maybe a bit bigger
i also don't think the carb is big enough
oh ps the tranny is an aod with a 3500 converter, shift kit and the rear has 4.56 gears with 33in tires
i kinda feel like i am losing a bunch (like 10-20hp) by not running either a solid flat tappett cam or a hydrolic roller cam, i want to be shifting around 6500-7k but i know a hydrolic cam just isn't going to want to go into that range
what do you guys think is this enough to get me into the 13s?
ps: i posted this in the smallblock engine section as well
Old 08-10-2009, 12:38 PM
Conanski's Avatar
Conanski
Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
You still need bigger heads with more compression to properly utilize that cam with your existing setup in my opinion, try to find some used TFS or AFR heads with 58cc chambers.
Old 08-11-2009, 09:59 AM
Conanski's Avatar
Conanski
Here's a simulation I did with a best guesstimate cam specs based on the info provided, the software calculates the valve timing from the basic specs but it would be nice to verify with the published specs. The graph looks much like I expected with a powerband that is all HP and no TQ. The cam I ran this against is the Comp 35-242-3 a flat tappet grind with a relatively tame 268/280 advertised duration, but the results speak for themselves. The Comp delivers 329hp at 5500rpm and 348Ft/lbs TQ at 4500rpm while your existing cam makes 326hp at 6000rpm but only 303 ft/lbs TQ at 5000rpm. Obviously the BIG story here is the TQ curve, at 3500rpm there is an 87 ft/lb difference which is hugh and would make quite a difference in ET since TQ is what accelerates the load.
Old 08-11-2009, 04:39 PM
1966Tbird's Avatar
1966Tbird
yeah i actually decided to use a set of trick flow twisted wedge heads http://www.summitracing.com/parts/TFS-51400010/
havn't ran it in the desktop dyno yet and don't know what the compression would be with the 61cc chamber but i am hoping to still be able to run pump gas
with those heads i am not going to be using the same camshaft that's in my truck now
and i think i am going to try a 650 carb and a 750 carb just to see what feels better on the street
and thanks for running those numbers for me things are crazy it seems everyone needs something done to their car recently so i have had no time to do anything
oh i have also decided to run a hydro roller cam just not sure what size yet i'll have to mess around with desktop dyno for a little bit
i am thinking with the new motor on spray i might break into the 13s and my current motor in my truck is going into my buddy's jeep which should be fun
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
