6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Poo88
Old Aug 29, 2013 | 06:33 AM
  #31
Gearitis's Avatar
Gearitis
Originally Posted by auriferous
Emissions warranty is 7 years, fuel pump is part of the emmissions
So the HPFP is part of emissions category on these trucks? Was not aware, if that is true, then Ford ESP warranties past 100k will exempt Emissions parts. Is that correct or am I not seeing the whole picture here. Does anyone know where a complete listing of Emissions parts are located that would be covered under a Ford ESP? I am with some of the others, since Steve had an issue and he is one that has a lot of experiece behind him, now makes me wonder? Reason for enquiring, at 99k and looking at the Ford ESP's for another 4 years. Hey if I need to start another thread on this, let me know...
Old Aug 29, 2013 | 06:46 AM
  #32
senix's Avatar
senix
From the warranty guide, 4th edition:
(4) Your vehicle’s direct injection diesel engine and certain engine components
are covered during the 6.0L/6.4L PowerStroke Diesel Engine
Coverage Period, which lasts for five years or 100,000 miles, whichever
occurs first. The following parts are covered during this extended coverage
period: the engine, cylinder block, heads and all internal parts, intake
and exhaust manifolds, timing gear, harmonic balancer, valve covers, oil
pan and pump, water pump, fuel system (excluding fuel lines, fuel tank
and frame mounted fuel conditioning module sometimes referred to as
the frame mounted pump/filter/water separator), high pressure lines, gaskets
and seals, glow plugs, turbocharger, two-stage turbocharger assembly
(6.4L), turbocharger actuator (6.4L), powertrain control module, engine
control module (6.4L), high pressure fuel injection pump assembly
(6.4L), electronic driver unit, injectors, injection pressure sensor, fuel rail
pressure sensor (6.4L), high pressure oil regulator, exhaust back pressure
regulator and sensor, exhaust pressure sensor (6.4L), manifold pressure
sensor (6.4L), intake air temperature sensor (6.4L), crankshaft position
sensor (6.4L), camshaft position sensor, accelerator switch.
NOTE: Some components may also be covered by the Emissions Warranties.
For more information, see pages 17-32.
  #33
senix's Avatar
senix
http://www.motorcraftservice.com/pub.../08frdwa3e.pdf
Old Aug 29, 2013 | 06:49 AM
  #34
senix's Avatar
senix
Emissions warranty:
List of Parts Covered for 5 Years or 100,000 Miles (whichever
occurs first) by Emissions Warranties for Diesel Engines
Air Flow Sensor
Air Induction System
Catalytic Converter (including
Diesel Particulate Filter and
Diesel Oxidation Catalyst)
Cold Start Enrichment System
Electronic Engine Control Sensors
and Switches
Electronic Engine Control Unit
(ECU)
Emissions Label
Exhaust Gas Recirculation
(EGR) System
Exhaust Manifold
Fuel Injection System
Fuel Injector Supply Manifold
Intake Manifold
Intercooler Assembly - Engine
Charger
Malfunction Indicator Lamp
(MIL)/On-Board Diagnostic
(OBD) System
PCV System and Oil Filler Cap
Supercharger Assembly
Throttle Body Assembly (MFI)
Old Aug 29, 2013 | 06:51 AM
  #35
senix's Avatar
senix
What I don't have reference too is the extend warranty coverages since I have the Geico which is pretty much bumper to bumper.
So those with an extended warranty, refer to your book.
I would appear to me that the HPFP could be covered either way, with the emissions or diesel warranty.
Old Aug 30, 2013 | 06:45 AM
  #36
Gearitis's Avatar
Gearitis
Understood on the warrany to 100k. With a lot of us approaching or over the 100k, the options to be covered with the Ford ESP over 100k and the details of the ESP show that emissions are not covered with these plans other than premium care which, according to my dealer Ford MAY exempt the HPFP due to conditions and only for 2 years. Really hard for me to swallow that a diesel engine does not have the longevity today that I was raised in the past. To drive down the hiway and always wondering if the HPFP or the injectors or something is going to go "bazinga" is rather concerning. If you do not have some type of warranty, it could literally "break the bank" to get home.
Old Aug 30, 2013 | 07:55 AM
  #37
Tom's Avatar
Tom
Unfortunately I think the durability advantage has been gone for years, but more of that has to do with the longevity of gas engines than the shortened life of diesel engines. Sadly bearings, rods, rings, and valves aren't new technology. Up until recently those have been the only things that could fail and cost big dollars, but those have been figured out pretty well enough to be components that nobody worries about anymore. But these new expen$ive fuel systems just haven't been out for the ~130-ish years that most internal engine components have been, so there's a bit of an experience curve before they become as reliable.
Old Sep 16, 2013 | 03:54 PM
  #38
AVE8R's Avatar
AVE8R
Geico MBD Insurance
Originally Posted by senix
I am not so sure. I am not totally sure why the failure. I know it is not water, nor is the HPFP coming apart.
There is no metal throughout the system.
My gut say VCV is the main issue. An Airdog or anthing else for that matter would not prevent that.
At any rate it should be up and running by COB tomorrow.
I am using the GEICO MBI insurance to pay for the repairs. so I am out 250 bucks plus my time at the campground here.
So all in all it could have been worst.
Won't be a totally ruined vacation just had to cut a couple of days out of it.
If you don't mind me asking, how much are you paying for that Geico MBD Insurance? I'm still under my Ford Extended Warranty, but this looks like something to consider.
Dave
Old Sep 16, 2013 | 04:02 PM
  #39
AVE8R's Avatar
AVE8R
So...here is my story. Right now I am in Midland Texas. Parked at a RV park in the dirt and the truck is parked in the shop at the Ford dealer.
I had the 11B23 flash couple years ago. In April it threw the Poo88 code so I got the TSB 12-7-7 update.
Towed heavy several times since and all was well. Even had some nice hot tows up I68 so problems.
So today outside of Midland I got the code again. I cleared it and it came right back. Fueled up and thought I would try again. no dice within few miles it was back on again.
Coolant temps have been running where you would expect in Mid 90 deg weather..around 210 with 220-228 spikes followed by the airplane and a cooldown.
towing speed is 65. I tried to slow down a bit but to no avail.
So what are the possiblilites that the TSB did not take?
Personally I think I am getting some new hardware.
thoughts?
I had the P0088 Code show up last week.
I have a 2010 Ford F-350 King Ranch 6.4L 4x4 DRW.
The cruise control stopped working, the truck was limping on initial acceleration, couldn't get past 50 MPH, and a scanner is showing a code: P0088 - Fuel Rail Pressure Too High.
I've changed both fuel filters at least every 10,000, and it has only been roughly 6,000 since both were changed. I drain the sump every two weeks, and I've yet to see any water. The truck has 36,120 miles.
I took the truck into Ford and they did the re-flash. (The 12-7-7 update)
Does anyone know whether this is a fix, or if I should expect the HPFP to start spitting metal into the fuel system?
I'm still under my extended warranty, but my understanding is that only extends the warranty an additional 12,000 miles and one year. When I bought it, I was told it was a 7 / 70 warranty, extending the factory warranty 48 months and 4 years AFTER the factory warranty expired. $2,600 bucks. I sure got ripped off on that one.
If anyone has any suggestions on the reliability of the re-flash, or any other suggestions, it would be appreciated.
Dave
Old Sep 16, 2013 | 04:11 PM
  #40
senix's Avatar
senix
Dave
Gieco's warranty is only offered if I recall correctly within the first 12 months/12K miles on new purchased vehicles.
I pay somewhere around 70 bucks for a 6 month policy and it is bumper to bumper to 100K miles.
250 dollar deductible.
Old Sep 16, 2013 | 04:13 PM
  #41
senix's Avatar
senix
Dave
If you had the tsb applied all you can do is drive it and see if your issue goes away. If It comes back then you have a bad hpfp or something within the hpfp.
All you can do.
Old Sep 16, 2013 | 05:38 PM
  #42
slowmans's Avatar
slowmans
you are correct, I declined to get it ...kind of wish I didn't.
Old Sep 16, 2013 | 05:42 PM
  #43
Tom's Avatar
Tom
This thread makes me want to return to Geico for their MBI! Of course my HPFP is only a $250 part...
Old Sep 16, 2013 | 07:00 PM
  #44
senix's Avatar
senix
Sure saved me a few bucks.
Bedlinedf250
May 14, 2019 05:57 PM
45bpcr
6.7L Power Stroke Diesel
Aug 1, 2018 10:27 AM
Keymaster
18
May 6, 2018 05:19 PM
markfh11q
1983 - 2012 Ranger & B-Series
Aug 29, 2007 04:51 PM
dullarrow
13
May 27, 2007 08:16 AM
