I'm just going to post this here. If anybody out there is having electrical problems, ie. pwr window inop. door lock switch inop. or you suspect a bad contact or connection somewhere etc etc etc...Before you spend a load of cash on switches, etc...
Spray some Deoxit D5 in the switch, connector etc.....The stuff is amazing. I've fixed too many items to mention them all with a 16.00 dollar can of the stuff. Turntables, receivers, door lock switches, window switches, etc....You can order it through WASSCO 800-492-7726 or Techni-Tool - Distributor of test-equipment, solder, soldering equipment, ESD & static control products, tools, and more..
