The engine runs rather smooth but here are the symptoms:
1. When I add a qt of oil to top off, a massive cloud of blue smoke comes out for only a few miles of driving then clears up.
2. There seems to be a loss of power.
3. Oil is frothy.
4. Burns oil a bit after condition above.
5. When i shift to reverse it sometimes stalls. Not sure if it is related or not.
What I did (I am kind of new to this part):
1. replaced head gasket but i did not know that I needed to have the heads checked. Dont know the significance of that.
2. Ran diagnostics but got no codes.
3. i adjusted the timing which was off a bit.
I know I need to have the heads checked but I just wanted to get other feedback before i take the top end off again.
sounds like you have a really bad valve guide, and seal, problem. ive got a 190,000 on my 4.9 and still runs perfect. the fact that right after you add oil it smokes is pretty much the oil is going over the valve guides and seals and leaking past them.
Good point IhDriver. I hadn't thought of that, but good possibility. Also as hotrod351 pointed out, if adding oil and then it smokes, worn valve guides, seals would allow that freshly poured oil, mainly driver side, to be sucked pass the worn seals. It's not extremely difficult to replace them with head on, just takes some time, patience, air compressor, valve spring compressor, and/or nylon rope.
I thought of the dipstick cause over the course of the summer, we've had about 5 clients come to the garage with exactly that problem. Usually handle snapped, so they went to scrapyard to get another one, same car, not same motor.
