Engine Issue
Old Aug 16, 2013 | 07:26 AM
chrisroy1972's Avatar
chrisroy1972
Engine Issue
Hi Everybody,
I have a 1990 F150; 5.0, E4OD; XLT Lariat 2wd.
The engine runs rather smooth but here are the symptoms:
1. When I add a qt of oil to top off, a massive cloud of blue smoke comes out for only a few miles of driving then clears up.
2. There seems to be a loss of power.
3. Oil is frothy.
4. Burns oil a bit after condition above.
5. When i shift to reverse it sometimes stalls. Not sure if it is related or not.
What I did (I am kind of new to this part):
1. replaced head gasket but i did not know that I needed to have the heads checked. Dont know the significance of that.
2. Ran diagnostics but got no codes.
3. i adjusted the timing which was off a bit.
I know I need to have the heads checked but I just wanted to get other feedback before i take the top end off again.
Thanks for any help!
Chris
Old Aug 16, 2013 | 03:08 PM
timbersteel's Avatar
timbersteel
Sounds like worn valve guide seals. Sounds<
How many miles on the engine? What prompted the head gasket change...I'm assuming blown head gasket.
Old Aug 17, 2013 | 09:01 AM
chrisroy1972
hi thanks. the truck has 95543 miles. the head gasket change came from a recommendation of a mechanic friend based on the frothy oil.
the other thing i wanted to note was the very thick blackish exhaust. it is very rich with gas/hydrocarbons smells.
chris
Old Aug 17, 2013 | 09:29 AM
Conanski's Avatar
Conanski
You say you got no codes, does that mean you got no response from the computer at all or you got the 11, 11 all clear codes?
Were you using a code reader or trying to flash the codes on the check engine light?
Old Aug 17, 2013 | 09:58 AM
hotrod351's Avatar
hotrod351
sounds like you have a really bad valve guide, and seal, problem. ive got a 190,000 on my 4.9 and still runs perfect. the fact that right after you add oil it smokes is pretty much the oil is going over the valve guides and seals and leaking past them.
Old Aug 17, 2013 | 09:19 PM
IhDriver's Avatar
IhDriver
Might be a stupid question, but do you still have the original dipstick? If not, maybe max line not at right spot, and you're putting a qt too much?
Old Aug 18, 2013 | 08:14 AM
timbersteel
Good point IhDriver. I hadn't thought of that, but good possibility. Also as hotrod351 pointed out, if adding oil and then it smokes, worn valve guides, seals would allow that freshly poured oil, mainly driver side, to be sucked pass the worn seals. It's not extremely difficult to replace them with head on, just takes some time, patience, air compressor, valve spring compressor, and/or nylon rope.
Old Aug 18, 2013 | 06:18 PM
IhDriver's Avatar
IhDriver
I thought of the dipstick cause over the course of the summer, we've had about 5 clients come to the garage with exactly that problem. Usually handle snapped, so they went to scrapyard to get another one, same car, not same motor.
pi653
Nov 26, 2016 10:10 PM
IceBerg04
Mar 20, 2014 04:18 PM
wolfgang031691
1997 - 2003 F150
Jan 20, 2011 03:25 PM
abreiholz
Nov 14, 2010 05:54 PM
89_Brnko2!!
Bronco II
19
Feb 20, 2009 09:43 AM
