Question, I have a 1989 F250 and when I turn on the headlights they dont turn on. The brake, and parking light all turn on. Where should I start looking at for the problem?
ill say fuses or dimmer switch. we tried to run my headlights on my 85 f250 without the dimmer switch hooked up and found they wont come on with the dimmer switch not hooked up. i used a switch from my 77 and it worked also.
I just the fuse box and the number the number 11 fuse which controls the headlights has power running through it and I just replaced the switch...still no luck....
And if all else fails, check the grounds. Shouldn't be too far away from each plug to the bulb. 9 times out of 10, wiring problems come down to the ground being corroded/rusted.
Thanks for the support. It was the dimmer switch. Sorry it took so long to reply but just picked up a 2013 f150 5.0. Still am working on rebuilding the 89 f 250.
