axle question
Old Aug 15, 2013 | 01:13 AM
Schickel's Avatar
Schickel
axle question
So my question is pretty simple. Do 2wd and 4wd axles mount the same on these trucks or are they different?
Old Aug 15, 2013 | 07:17 AM
Freightrain's Avatar
Freightrain
Are you asking if the front and rear axle mount the same? The front is on coil springs, the rear is leaf.
Old Aug 15, 2013 | 11:56 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F250 4WD's have front and rear leaf springs.
Old Aug 17, 2013 | 10:59 PM
orich's Avatar
orich
What, I found out with a 70 2wd rear 60 dana axle look the same, but found that the welded on shock mount was welded on in a different place on a 70 2wd by about 2.5-3 inches versus the my 71 dana 60 4wd axle. I was still able to hook up the shock tho! The E-brake cables are also different lengths. I made the switch and thats what I found to be different that, I noticed. It was a 70 2wd Explore f250 that had some type of limit slip carrier in the rear is why I switched plus the bearing race area was in better shape than mine. my 2 cents orich
DeanBob
Jun 4, 2017 10:47 PM
68 Super Crew
Oct 18, 2009 08:55 PM
stevegold1958
Jul 30, 2007 09:04 PM
mustanginca
Mar 14, 2007 10:13 AM
Big_Hauler95
Offroad & 4x4
Apr 27, 2003 08:51 PM
