Well I started accumlating parts to install the 7.3 IC. I'll need four 3" diameter boots. I saw Riff Raff diesel sells straight boots, but I was looking for some that have prebent angles. Any other suppliers out there?
^^^ Has different bends and angles. I couldnt be happier with them and there service.
And there is a place in texas that charges 120$ sent to your door for a e99 spyder. Let me know if you need the number
I'm checking out the silicone boots at this website. Their reducer for the spyder to plenum are either 1/8" smaller or larger than the 2-3/8 - 2 inch OD specs required. Can silicone stretch w/o issue, as I'm thinking the smaller is better for a tighter fit.
If I were you I'd go with the ones from riffraff. I wouldn't want to have one and 1/8 bigger in case it won't seal, and the 1/8 smaller is going to make getting that spyder on a real pain in the you know what. The riffraff boots are top quality.
Hey thanks, that's what I needed to know. Everything I've gotten from Riffraff has been good to go.
