Vibration
Old Aug 14, 2013 | 06:23 AM
skipper159's Avatar
skipper159
Vibration
I got a 2011 f-150 ecoboost and when I travel any long distance I get a bad vibration when turning from the rear of the truck. It does not happen when it is just a short trip. Does anybody know what this could be?
Old Aug 14, 2013 | 06:30 AM
Robbgt's Avatar
Robbgt
Hello and welcome to FTE. Sorry to hear about the issue. Does your truck have a Limited Slip differential? If so, you may be having an issue with the clutch packs in the diff. Here is another thread on the similar issue: https://www.ford-trucks.com/forums/1...left-turn.html
If your truck is still under warranty this should be covered
Hope this helps
Old Aug 14, 2013 | 07:25 AM
skipper159's Avatar
skipper159
Yes I do have the limited slip diff. I still have warranty so it will be covered. Hopefully that is what it is. Thanks for the info.
Old Aug 14, 2013 | 10:10 AM
GuyGene's Avatar
GuyGene
Keep us posted on this one, Skip. And, welcome to a friendly and helpful and respectful F150 forum!!
Old Aug 14, 2013 | 10:53 AM
NorminN.B.'s Avatar
NorminN.B.
If it's still under warranty, take it to the dealer, explain what it is doing, and they will probably add some friction modifier to the rearend. That should take care of it.
Old Aug 14, 2013 | 01:48 PM
Gerby Dutchy's Avatar
Gerby Dutchy
depends how worn the clutch packs are otherwise friction modifier doesn't help
Old Aug 14, 2013 | 02:52 PM
NorminN.B.'s Avatar
NorminN.B.
thats true, but I wouldn't think a 2011 clutch pack would be wore out unless it was bad from the factory or abused. LOL
Old Aug 15, 2013 | 07:32 AM
FordService's Avatar
FordService
Official Ford Rep
Hi skipper159,
I wanted to reach out to you and see how things are going with your truck. If you haven't already, I recommend making an appointment at your dealership so they can check things out. Touch base with me when you get a diagnosis and, if needed, I'll jump in and assist.
Crystal
Old Aug 15, 2013 | 10:19 AM
Gerby Dutchy
Depends how long it has been vibrating but modifier doesn't cost a lot so its worth a try
Old Aug 30, 2013 | 10:50 AM
skipper159's Avatar
skipper159
truck fixed
They had to replace the clutch pads. They told me this is not the first truck they had to do it to. Then a couple of days before I brought the truck in the check engine light came on. When they checked it was the timing chain that had to be replaced. The truck only has 70,000 km on it. They had the truck for 8 days but seems to be working fine now. Is this a common problem with these trucks too.
Old Aug 30, 2013 | 05:58 PM
PrinceValium's Avatar
PrinceValium
So they replaced the rear end clutch packs????? This is what I think is my problem.
Old Aug 31, 2013 | 08:24 AM
NASSTY's Avatar
NASSTY
I'm pretty sure you have the electric locking differential. If so you don't have clutch packs. Only trucks with the limited slip differential have clutch packs.
Old Sep 7, 2013 | 10:31 AM
Big-Red-Lariat's Avatar
Big-Red-Lariat
had the vibration on my 2011 during left turns. Truck bought new & never abused. Replaced clutch pack under warranty & corrected problem.
Not sure I understand why they needed changing at only 30,000 miles. So are the originals defective or improperly installed at factory or what???
xupkid2
Oct 23, 2011 07:47 AM
gui88ford
2004 - 2008 F150
18
Apr 13, 2010 06:56 PM
chalo1981
1997 - 2003 F150
67
Mar 20, 2010 04:34 PM
tonyhake
2004 - 2008 F150
Aug 30, 2005 06:25 AM
jrangel
Nov 10, 2003 10:40 AM
