Vibration during left turn
on
Vehicle has a vibration most prevalent when cold during a left turn especially first thing in the morning. Feels kinda like 4x4 is on, but its not.
Tech test-drove it and tells me it needs "clutch packs".
Has anyone changed clutch packs to address this issue, and did it correct problem?
If I let him change them, am I in danger of screwing anything else up in the process?
& what the fuxa clutch pack anyway?
Sometimes you can resolve the clutch pack chatter by adding some more limited slip friction modifier (available at Ford dealer or auto parts stores) to your rear differential fluid. I had to replace the clutch packs in my 2000 F-150, so I went ahead and swapped in an Auburn Gear unit... Much nicer, but not rebuildable like the Ford unit. Now I'm glad I got the ELD... no more clutch packs.
Just as an FYI, you can see if your vehicle has any applicable recalls by entering your VIN here: Personalized Vehicle Owner Information
Crystal
4601ton
29
04-27-2012 11:54 AM
ReFlectiveMan
09-01-2010 07:23 PM
