Sponsored by: Auxito
P0340 cam position?
Old Aug 14, 2013 | 12:42 AM
rollinblackcloud's Avatar
rollinblackcloud
P0340 cam position?
Hey guys, the p0340 code is the cam position right? Ready says bank 1.. Is there 2? Can anyone tell me where the bank one is?? nd do i need to get on tdc on cyl one first or not?
Old Aug 14, 2013 | 10:53 AM
Bluegrass 7's Avatar
Bluegrass 7
On a 4.2L v6 it is in the old distributor location that set in a hole on top front of motor.
On 4.6/5.4L v8 it' the sensor screwed into the front of head on 'driver side' with a connector attached.
It has to detect the movement of the cam gear hence it's location.
Good luck.
Old Aug 14, 2013 | 10:56 AM
rollinblackcloud
Ok great, do i have to get on tdc for eather of these engines?
Old Aug 14, 2013 | 11:13 AM
Bluegrass 7
Which motor are we talking about v6 or v8.
On v6 you need to follow a procedure because it's timed (driven) off the camshaft.
On a v8 you can't do anything but screw the sensor into the head so it can sense the passing of the cam gear surface change to generate it's signal..
Good luck.
mdr617
1997 - 2003 F150
Nov 1, 2017 09:43 PM
Plowboy34
1983 - 2012 Ranger & B-Series
Feb 13, 2012 08:25 AM
Therickster
1997 - 2003 F150
Dec 18, 2006 10:09 AM
Jitters
1997 - 2003 F150
Nov 2, 2006 02:34 PM
Paora01
Mar 28, 2005 01:55 PM
