cab removal
Old Aug 13, 2013 | 08:43 PM
zombiefied 247's Avatar
zombiefied 247
cab removal
I am looking to remove the cab from my 55 my question is if my floors are solid as are my door jams do I really need to brace it up to remove it?????
Old Aug 13, 2013 | 09:14 PM
Harrier's Avatar
Harrier
No, you can remove it without bracing. I just pulled mine off yesterday. With the doors off, it's not too heavy.
Do you have a plan to pull it off? If you have 3 or 4 people it's quite easy. I don't so, I used the seat bolt holes and the front cab mount holes. I put chains on them and attached them to my engine hoist in the center (toward the front because the front is much heavier.) and lifted it right off.
Old Aug 13, 2013 | 09:41 PM
Harrier's Avatar
Harrier
Here is a thread talking about a similar method using chains inside the cab.
https://www.ford-trucks.com/forums/1...the-frame.html
And here is a nice thread about a cab dolly:
https://www.ford-trucks.com/forums/1...g-the-cab.html
Old Aug 13, 2013 | 09:57 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
So that's how it's done. Duh!
I've heard of people taking off the cab with an engine hoist, but couldn't figure out how to get it high enough to clear the frame.
You would think someone that removed the transmission from a deuce and a half by reaching in with an engine hoist would have figured that out. I guess not.
Old Aug 13, 2013 | 10:03 PM
Harrier's Avatar
Harrier
You should have seen my first attempt. It worked, but I won't show it to anyone. It involved tie down straps and a 4X4. The chain way worked well.....once you balance the cab....yeah I was sweating the first attempt with the chain method as I'm struggling to save the cab from flailing all over the place. I managed to get it back to the frame and said, "Well I guess they were right that the front is much heaver...." Sometimes I'm a little dense.
Old Aug 13, 2013 | 10:25 PM
KGP50's Avatar
KGP50
All good ideas here for working with the tools that you have. Here's a little different adaptation of a hoist to remove a cab. I constructed it for use on my '41 Ford PU project using some scrap 2x4s and 2x6 pieces... works great.
Old Aug 14, 2013 | 01:41 PM
arctic y block's Avatar
arctic y block
That's pretty fancy KP. Damn good job.
Old Aug 14, 2013 | 03:43 PM
fking1's Avatar
fking1
That's how I removed mine except put chains around the 2x4s with the hoist on top over the cab.
Old Aug 14, 2013 | 04:03 PM
jniolon's Avatar
jniolon
old and in the way
zombie
I did similar to KGPs... 'sept I used 2 landscape timbers (way overkill)... bolted them together with spacers the same width as the lift arm... removed the hook from the chain hoist and use a piece of 3/4 allthread to bolt the timbers above the arm... rolled it into the cab with the doors open )(they are already fitted up nicely) and jacked it up... rolled it to the side of the frame and set it down on the cab dolly...
I have done mine with the same hoist and a nylon sling through the doors and lifted it... it tended to roll the rail gutter so I didn't do it this time. If you have 4 friends it works good too.... I don't have 4 friends..
later
j
Old Aug 14, 2013 | 08:46 PM
zombiefied 247
thank for all the reply's everyone!!!!! its very much appreciated.... cab comes off this weekend......
Old Aug 14, 2013 | 09:33 PM
DGMFORD's Avatar
DGMFORD
I've taken mine off several times, with the doors off, if you don't use a hoist, three people can remove it with ease. I have someone kind of manage the front as they attend to be front heavy and lean a bit towards the front. Also I when to HD and purchased some small 3 wheel dollies and set the cab on them so I could roll around with ease.
lshobie
Nov 23, 2017 08:38 AM
8086ford
Sep 16, 2016 08:05 AM
ED Milk
Aug 20, 2011 08:30 AM
tomtoc
1983 - 2012 Ranger & B-Series
Feb 5, 2007 06:34 PM
