Cooling Fan
Old Aug 13, 2013 | 02:41 PM
  #31
Yahiko's Avatar
Yahiko
I'll play with the settings today to see what it does.
Sean
Old Aug 13, 2013 | 08:14 PM
  #32
Roasted7's Avatar
Roasted7
Originally Posted by BLADE35
You have SGII Right??
We probably see alittle info with SGII on the Fan
Take Fan RPM At Low and High Idle EOT Above 185* when Taken
What bings the Fan into ????
<table width="749" dir="LTR" border="1" cellspacing="0" cellpadding="7"><tbody><tr><td width="14%" height="3" valign="TOP"> FANSS
</td><td width="14%" height="3" valign="TOP">Fan Speed
</td><td width="14%" height="3" valign="TOP">0
</td><td width="14%" height="3" valign="TOP">533
</td><td width="14%" height="3" valign="TOP">488
</td><td width="14%" height="3" valign="TOP">0 - 4000
</td><td width="14%" height="3" valign="TOP">RPM
</td></tr></tbody></table>
I'm not understanding this chart.
Old Aug 15, 2013 | 09:41 PM
  #33
Roasted7's Avatar
Roasted7
I found an xguage for fan duty cycle but it doesn't work. Does anyone know another code?
I have this: FDC %
TDX: 07E022091F
RXF: 04624509061F
RXD: 3010
MTH: 013103E80000
I can watch the rpm's but it seems meaningless unless I know what it wants verses what it's getting.
Old Aug 15, 2013 | 11:46 PM
  #34
BLADE35's Avatar
BLADE35
That's^^^Fords FAN Value what Fan RPM you should get at
KOEO
Low Idle
High Idle (2500 Truck rpm)
In the First 3 Box with numbers
The First 0 is at KOEO
533 is the FAN RPM at Low Idle EOT@185*+
488 FAN RPM is @ Truck at 2500RPM
Old Aug 16, 2013 | 09:05 PM
  #35
Roasted7's Avatar
Roasted7
Here's what I got:
With eot 202 and ect 198
low idle fan rpm=355
high idle fan rpm=580
I have no clue what this means.
I'm running Matt's SRL tune. Could that be suspect?
Old Aug 16, 2013 | 09:16 PM
  #36
BLADE35's Avatar
BLADE35
you would need to ASK him about tune
Must test with A/C OFF
Old Aug 16, 2013 | 09:27 PM
  #37
Roasted7's Avatar
Roasted7
AC was off.
Old Aug 16, 2013 | 10:07 PM
  #38
BLADE35's Avatar
BLADE35
Originally Posted by Roasted7
AC was off.
I was afraid of that
Low Idle seems Slow
Not really the Best way to test it
Hows the Belt?/ OK?? Tensioner
Any DTC??
Old Aug 16, 2013 | 10:18 PM
  #39
Roasted7's Avatar
Roasted7
I'm going to give it a good check over this weekend.
Old Aug 16, 2013 | 10:36 PM
  #40
Roasted7's Avatar
Roasted7
Here is what I've noticed after a couple days of observation.
When the engine is cold the fan will run at about 500ish at idle.
When the engine is hot the fan runs around 350ish.
Seems back assward to me.
Old Aug 16, 2013 | 10:46 PM
  #41
BLADE35's Avatar
BLADE35
Originally Posted by cheezit
command fanvar# to 100% moniter for incress in fanss. also moniter rpm and varify fannss is at least 2800 with rpm at 2500.
i run them up past that to test for a slipping belt
With This^^ as the RULE
I found this NEVER TRIED IT Below it should work
I found this from Bismics Post at the ORG
http://www.justanswer.com/ford/1grjp...n-off-fan.html
Grounding the Dark Blue wire will engage the fan full on. The PCM does monitor
fan speed and may set a code but should not cause any ill issues as long as you
do not cut the wire where the PCM cannot engage it when it wants to. I hope
this helps.
Sounds like you ground Dark Blue wire and that Comands Fan at 100%
tHAT LOOKS LIKE PIN#4 at the Plug
then whatch FAN rpm with SGII and APPLY Cheezits RULE!!
Old Aug 16, 2013 | 10:57 PM
  #42
BLADE35's Avatar
BLADE35
Looks like there maybe More than One Way to Skin a CAT I thought there should Be just took a Minute to Find it
No Punt Intended SEAN LOL!!
If you trty it let Me know how it worked thanx
Old Aug 16, 2013 | 11:00 PM
  #43
Roasted7's Avatar
Roasted7
I'll give it a shot and report back.
Old Aug 16, 2013 | 11:05 PM
  #44
cheezit's Avatar
cheezit
benny thats good to know thank you
Old Sep 8, 2013 | 02:16 PM
  #45
Roasted7's Avatar
Roasted7
My buddies diagnostic tool verified that the fan works correctly.
This pretty much just leaves either a clogged up radiator or a water pump going bad.
1986F150six
Nov 6, 2016 09:27 AM
samsdad02
Nov 27, 2014 08:30 AM
eddiedebb
Jul 12, 2011 08:27 AM
