replacing o2 sensors
Old Aug 11, 2013 | 11:41 AM
LincolnMan1's Avatar
LincolnMan1
Question replacing o2 sensors
Hello
The vehicle in question is a 98 Explorer with the 4.0L. All I have right now is the Haynes manual. I plan on getting the shop manual very soon. Is there a trick for replacing the O2 sensors. One individual said you need to remove the whole exhaust system to do this. The pics in the Haynes manual are useless. How do you disconnect the electrical connectors as they are very far up in the engine. If anyone who has done this could give me some pointers I would really appreciate that. Thanks in advance.
Tony L.
Old Aug 12, 2013 | 09:54 PM
Graygeorge's Avatar
Graygeorge
The wire connectors are about 12 inches from the O2 sensors. Some have a safety clip that needs to be pull out before disconnecting the sensors wires. I used an O2 sensor removing socket kit from o'reilly's that work great. You can borrow it, then return it.
Old Aug 15, 2013 | 11:20 PM
Mikeman's Avatar
Mikeman
I doubt you would have to remove part of the exhaust to get the O2 sensor out. Ford has done some stupid things, but I can't imagine they'd do something that stupid.
I've had to remove part of the exhaust on my Honda because the sensor was stuck in there really good (or bad). On my Ranger, the hardest part about removing the sensor was getting the connector apart. Access to the connector was ****-poor. It probably took me an hour of trying to access the dang connector from every possible angle so I could get it apart without damaging the wires. Once I got the connector apart, the sensor was off in 30 seconds.
Take a peek yourself and evaluate the situation. Also, check youtube for videos.
Old Aug 16, 2013 | 07:54 AM
Flip4ford's Avatar
Flip4ford
Reach in from the top-- you have to "blind Mans feel" your way down the wire and disconnect it. nothing special-- just hard.
JOE SKI
1997 - 2003 F150
Nov 4, 2008 12:21 PM
anfo
Jan 6, 2008 05:46 PM
eigenvector
1983 - 2012 Ranger & B-Series
Aug 31, 2006 09:22 AM
pauld30338
Nov 16, 2005 07:14 AM
vincep38
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 22, 2003 07:44 PM
