Stopped charging??
Old Aug 11, 2013 | 09:40 AM
RonaldJ123's Avatar
RonaldJ123
Stopped charging??
Why did my 1972 ford stop charging? The alternator was rebuilt last year and I replaced the voltage regulator and it still doesn’t charge.
Old Aug 11, 2013 | 10:37 AM
HIO Silver's Avatar
HIO Silver
Parts sometimes fail regardless if they are new.
It's a old truck with old(er) technology.... it's not a friggin' toaster.
Old Aug 11, 2013 | 11:08 AM
montana_highboy's Avatar
montana_highboy
My grandma has a pre war (WWII) toaster....it can electrocute a small child....... but it makes a mean piece of toast.
Old Aug 11, 2013 | 02:32 PM
tsix's Avatar
tsix
Do you have access to a voltmeter? If so check for 13+volts coming off the regulator with the engine running. You may need to rev the engine a bit to get the voltage up. A good place to take the reading is at the starter solenoid.
If you get low/no voltage from the regulator, check it right at the alternator.
Also, make sure the belt is tight.
79ranger150
Sep 9, 2014 12:10 PM
forddieselnewb
Oct 30, 2012 07:41 PM
frankyford
Jul 25, 2009 05:11 PM
blixx003
May 29, 2004 11:24 PM
canadianfordman
May 1, 2002 11:24 PM
