Alternaor Check
Old May 29, 2004 | 10:17 AM
blixx003's Avatar
blixx003
Smile Alternaor Check
My 7.3 runs, but the alternator light stays on, and my gauge shows low charging too. How do I check the output of my aternator?
blixx003
Old May 29, 2004 | 02:51 PM
jroehl's Avatar
jroehl
Simplest way is to put a voltmeter on your battery with the engine running (turn ALL accessories off). The voltmeter should read over 14 volts. Anything much less than that, and I'd get that alternator rebuilt.
Jason
P.S. It wouldn't hurt to start by cleaning/tightening all electrical connections around the battery, alternator, solenoid and starter.
Old May 29, 2004 | 10:03 PM
DPS3749's Avatar
DPS3749
blixx003
Before condemning the alternator make sure the voltage regulator isn't the culprit by eliminating it from the circuit to see if it's good. If you have an external voltage regulator unplug the voltage regulator connector, and insert a piece of 14-gauge solid jumper wire from the connector terminal marked "A" (Battery) to "F" (Field). Run engine over 1500 RPM with "no load", and if you get 14 volts by-passing the regulator, but not after re-connecting the plug then your voltage regular is bad.
I'm not familiar with the internal regulators, since I never owned anything that new.
Old May 29, 2004 | 11:24 PM
DPS3749's Avatar
DPS3749
blixx003
If your engine is a non-serpentine belt one the first thing I'd check would be to make sure the alternator belt is tight.
