68 grill
Old Aug 11, 2013 | 08:58 AM
Fifty4F100's Avatar
Fifty4F100
68 grill
I'm looking at a 68 F100 in my area for $4800. It looks nice and has a 390 with I think a C6. Thing is its missing the grill inserts. LMC doesn't show any for the 68. Ebay only has one complete grill that I can find and its going for $675. Whats up with that? Can other years fit this truck?
Old Aug 11, 2013 | 09:19 AM
limegoldf100's Avatar
limegoldf100
'67-'69 have a one-piece grille (no inserts). All years from '67-'72 will fit but '70-'72 have different parking light arrangement.
Old Aug 11, 2013 | 09:39 AM
MIKES 68 F100's Avatar
MIKES 68 F100
Here's what your 68 grille should look like ,but without the ranger badge
sounds like you have a later grille on it .
Old Aug 11, 2013 | 10:03 AM
Area351's Avatar
Area351
I have a spare aluminum grille that I won't be using.
It's not perfect but pretty nice overall if you need one. I decided to keep my painted steel grille.
Old Aug 11, 2013 | 01:24 PM
Fifty4F100's Avatar
Fifty4F100
Here is a link to the truck. Is this a 68 grill?
68 Ford F-100
Old Aug 11, 2013 | 02:02 PM
gangstakr's Avatar
gangstakr
That's a 71-72 grille. The inserts can be either the 71 style or the 72 style.
Definitely not 68
Old Aug 11, 2013 | 02:17 PM
RichS2659's Avatar
RichS2659
It also has a 70-72 bed with the marker lights. Is it really a 68? And is it really a 390? Do a stroke test for sure.
Old Aug 11, 2013 | 04:17 PM
flyboy2610's Avatar
flyboy2610
It's got a 4 speed, not a C6. It's a nice truck, but it doesn't look $4800 nice to me.
Old Aug 11, 2013 | 05:57 PM
Area351's Avatar
Area351
Ditto.
I wonder what's hiding under that shiny red paint too.
Old Aug 11, 2013 | 06:03 PM
arctic y block's Avatar
arctic y block
Originally Posted by Area351
Ditto.
Chickin wire, bondo and fiber glass ya think?
Old Aug 11, 2013 | 07:03 PM
Fifty4F100's Avatar
Fifty4F100
Seems like I should be able to take this information and get a much better price. I wonder if NAPA or AutoZone will have a bondo tester?
What is the stroke difference between a 390 and 360?
Old Aug 11, 2013 | 07:44 PM
Area351's Avatar
Area351
A magnet covered up with a rag (so you don't scratch the paint) is all you need to check for bondo.
Old Aug 11, 2013 | 07:50 PM
RichS2659's Avatar
RichS2659
Stroke test:
https://www.ford-trucks.com/forums/1...and-390-a.html
It also has the Ford dual crease front bumper meaning it's been hit on both sides.
Old Aug 11, 2013 | 08:10 PM
elgemcdlf's Avatar
elgemcdlf
Filled seams on the hood & bed. May be nothing but may be due to rust & trying to hide it. Also missing hood badges & F-O-R-D. That grille shell has a piece of trim (actually it is 3 pieces to make 1) that goes across the bottom of the hood. Many guys have run into serious rust in their hoods so I would look that over very well. Missing center cap on the RF wheel. I would dig into bolt circle. The 8.8 is a smaller circle than stock. If the front is matched how was it done? Was the rear matched to the front? If so how? Is it mismatched? I agree with what has already been said. Not what I would expect out of a $4800 truck BUT I have noticed the prices on bumps & dents (especially SWB) climbing.
I too would be checking stroke. Not that it would really matter to me other than honesty. There is no visible difference between a 360 & a 390. 360s magically become 390s when it is time for sale.
Old Aug 11, 2013 | 08:49 PM
gangstakr's Avatar
gangstakr
The lower valance is from the 67-69 years. Notice how the turn signal housings sit. The 70-72 lower valance has a larger area for the turn signal housings.
I'm sure that red paint is hiding cancer.
Body lines don't look right. If you get a chance to crawl under it look at the cab mounts and core support mounts.
Chances are the trim holes were filled with bondo. Check those areas for cracking. And the hood lip, as was pointed out. If any of the hole areas are cracking this bondo job was not done right. Don't want to hit a pot hole.
