68 grill
Old Aug 11, 2013 | 09:02 PM
Area351's Avatar
Area351
An 8.8 out of a later F150 or Bronco would be the correct 5 x 5 1/2 bolt pattern.
Maybe he just moved the spring perches if even necessary.
The more we look, the more we don't like. I wouldn't buy it unless it was real cheap.
Old Aug 11, 2013 | 10:03 PM
crazed87bronco's Avatar
crazed87bronco
I'd be weary of this truck like mentioned by others has a mix and match full of parts and alot of the body lines that were filled in need alot of prep work to get all that rust, dirt, seam sealer who knows what else and get it prepped so it doesn't crack the filler down the road ask him if it was all just body filler over all the badging holes and body lines or if they did it right and weld them shut also be sure to find some kind of proof it's a 390 whether it be from a rebuild slip or measuring the stroke everyone seems to have a 390 when it comes time to sell and look for underbody rust floors cab corners and mounts under hood bottom of radiator support and find out what that rear is from make sure it has matching lug pattern seems Alittle high on price interior needs done yet but if the body checks out good and paint prep was done right then its not to bad of a deal
Old Aug 12, 2013 | 08:01 AM
elgemcdlf's Avatar
elgemcdlf
I got stuck in Explorer mode. Totally forgot they put the 8.8in almost everything rear wheel drive.
Old Aug 12, 2013 | 08:19 AM
Area351's Avatar
Area351
I knew that you knew.
Lol
Old Aug 12, 2013 | 08:56 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
In addition to what's been previously mentioned...
The grille shell could be 1970 only, or 1971/72. 1970 grille inserts are the same right/left, so the shell is 1970 only.
1970: Ford sold the grille inserts (D0TZ-8150-B) by themselves, but when you bought the grille shell (D0TZ-8200-D), it came with the inserts.
1971 & 1972 grille inserts are right & left specific. The inserts were available separately as was the grille shell.
1971 Ranger/Ranger XLT: Mouldings (D1TZ-8419-A R/L same) clipped onto the right/left grille inserts.
1971 grille inserts have two vertical dividers, 1972's have one (pic shows '72 inserts).
The Custom nameplates on the right/left bedsides were introduced in 1970.
Stylesides: 1969 from serial number F70,001, 1970/72 body side marker lamps have bulbs. This truck's bed has the earlier reflectors.
1969/72: Came with reflectors below the tail lamps that are missing. Truck has stainless steel w/shield reveal mouldings, would have come with tail lamp bezels. No see um.
Stroke: 360 = 3.50" / 390 = 3.78."
8.8" introduced in 1983 F100/150 & Bronco, but 9" was available thru 1986, so 1983/86's could have either.
CAVEAT EMPTOR ~ Let the buyer beware! 1980/83 F100: Some have 5 lug 5.50" bolt circle wheels, some have 5 lug 4.50" bolt circle wheels.
Old Aug 12, 2013 | 10:16 AM
gangstakr's Avatar
gangstakr
True to what NumberDummy says however the grille in question is a 71-72 look at the mounting area, the mounting area has 6 mounting tabs not 4
Ford F-100
<section class="userbody"> <figure class="iw">
</figure></section>
Old Aug 12, 2013 | 11:30 AM
elgemcdlf's Avatar
elgemcdlf
Ford F-100
</figure></section>
I knew there was a reason you stayed with '71/'72 & did not include the '70. Not being familiar enough with the split grilles I just waited to see what would pop up. I agree with the body line comment you made. Something just doesn't look right about the truck.
Old Aug 12, 2013 | 06:20 PM
Fifty4F100's Avatar
Fifty4F100
This is why I will always be an FTE member! Thanks guys.
Old Aug 13, 2013 | 03:03 PM
68fish's Avatar
68fish
Originally Posted by MIKES 68 F100
Here's what your 68 grille should look like ,but without the ranger badge
sounds like you have a later grille on it .
***NICE***
Joeceno
17
Dec 9, 2014 12:18 PM
Bears-72
Jun 2, 2011 02:15 AM
army_guy
Jun 7, 2005 10:05 AM
JPeacock212
Feb 6, 2004 12:04 AM
rjhewitt
Dec 3, 2001 03:18 PM
