How do I Identify an 360 and 390
- disconnect the coil wire
- remove one spark plug - for convenience, #1 or #5. As a Ford owner, of course you know which cylinders those are, right?
- insert a wooden dowel (or other rigid object that fits)into the spark plug hole and manually turn the engine using a socket and ratchet on the crank bolt to bottom dead center for that cylinder. Try to keep the dowel is vertical as possible.
- mark the dowel even with the valve cover rail (or other reference point).
- turn the engine to top center for that cylinder and make another mark even at the same reference point
- measure the distance btwn the marks.
A 360 will be 3.5 inches.... a 390 will measure a hair more than 3.75 inches (actually, 3.78 inches).
And there ya go...
Sorta.. The spark plugs are at an angle so yer not gonna get it perpendicular - close but not 90°. Try the method in my second post and you'll see.
on
Aw geez, I've been doing 1 & 5 for yrs same same....When at the junkyard and looking for a 390 block. I use a vehicle radio antenna ball tip first for a quick stroke check so, I don't need to carry a wooden stick about. a Felt pen always carry a tape Measure anyways tho.. my 2 cents orich
I am reopening a dated post here. I have been chewing on what Hio wrote for a week and have a couple of thoughts:
First, I think that this is the most informative, useful piece of information that has come across this site in a long time. For years I have seen guys post the same question: How do you tell the difference between a 360 and a 390. The answer always comes back: pull the pan, pull a head, measure, you can't tell externally. Hio has put up a simple method to tell the difference and proven it by photos.
I have a related question. Periodically the question of a slipped timing chain comes up. The short answer is pull the cover, have a look. But maybe Hio's method of measuring displacement can be used to feel out true TDC with a dowel and dial indicator and compare it with what the timing mark says?
Hio? Anybody?
Well done, Hio.
Semper Fi
Hio? Anybody?
Well done, Hio.
Semper Fi
Hio? Anybody?
Well done, Hio.
Semper Fi
Hio? Anybody?
Well done, Hio.
Semper Fi
The dowel measurement method has been discussed for a long time but I had yet to see pics so figured "why not" since my rig is disassembled and is less of a pain in the azz to do.... Btw, I purposely chose cylinders 1 and 7, instead of 1 and 5, because the cranks arms are 180° out of phase from each other.
I see what you mean by using the dowel method to feel out TDC. Yeah, it'll work but the dowel will be at an angle plus dowels swell and shrink with humidity. For an eyeball estimate, yeah it'll work.
on
So no moving to the other side of the vehicle. ..my 2cents..orich
R202INT
05-24-2014 06:56 PM
cabloom300
03-28-2010 11:44 PM
