Sponsored by: Real Truck
Excursion 4x4 issue
Old Aug 10, 2013 | 08:48 PM
Kdr358's Avatar
Kdr358
Excursion 4x4 issue
I've been tracking down all sorts of issues in my 4x4 lately and I have a few quiestons. I have an issue where everything is spinning as I drive even in 2wd. I gutted my hubs and removed the driveshaft. I had new u joints put in the front shaft today and re installed it. I still have the same issue of everything spinning while driving in 2. I had my marks move with the shaft in or out. I assume its getting tward front axle joint time. The shop owner said there should not be any movement in 2 but every SD I've seen has the axles spinning driving around town. I'm just confused because I have the entire driver side axle move when I spin the shaft by hand. Sorry for the blob of text as I am on my phone!
Old Aug 10, 2013 | 09:03 PM
redford's Avatar
redford
FTE Leadership Emeritus
If the axles are spinning, it is a hub issue.
Old Aug 10, 2013 | 09:23 PM
Kdr358's Avatar
Kdr358
The strange thing is that the hubs are hollow except for the outer piece (warn manual hubs). The main thing is when I spin the front shaft, the drivers side axle will spin wich confuses me. Please excuse my lack of 4x4 knowledge!
Old Aug 10, 2013 | 09:26 PM
99f350sd's Avatar
99f350sd
Its not real hard to check whats going on. Jack up one wheel spin it with the hub unlocked if the axle spins the hub is locked...Do the same for the other...If neither axle spins then the transfercase is locked in 4wd..Easy
Old Aug 10, 2013 | 09:59 PM
EXv10's Avatar
EXv10
One of the axles are supposed to spin if you turn the front shaft by hand (if you hold the other axle). The axles can spin if there is enough friction coming from stub axle (short outer axle) also. You can also turn the front drive shaft by turning one of the front axles by hand. There is no disconnect at the front differential but there is at the t-case and at the front hubs. If you stop the front drive shaft and spin one axle by hand the opposite axle will spin in the opposite direction. If 2 people hold the 2 front axles you won't be able to turn the front driveshaft until one of them lets go.................grasping it yet?
Old Aug 10, 2013 | 10:09 PM
Kdr358's Avatar
Kdr358
Originally Posted by EXv10
One of the axles are supposed to spin if you turn the front shaft by hand. The axles can spin if there is enough friction coming from stub axle (short outer axle) also. You can also turn the front drive shaft by turning on of the front axles by hand. There is no disconnect at the front differential but there is at the t-case and at the front hubs. If you stop the front shaft and spin one axle by hand the opposite axle will spin in the opposite direction.
That makes sense, thanks! I figured since the hubs were hollow nothing world happen but there is no binding as if the case is engaged. So I guess all I normal!
Old Aug 10, 2013 | 10:30 PM
99f350sd's Avatar
99f350sd
Normal? Axles are not supposed to turn in 2wd at all ever while you are driving.
Old Aug 10, 2013 | 11:16 PM
EXv10's Avatar
EXv10
Ever? They do if the hubs are locked, or if there is enough friction coming from the hubs or hub. If everything is working well, hubs unlocked, and t-case not in 4wd, the axles should be static while driving.
Old Aug 11, 2013 | 12:02 AM
99f350sd's Avatar
99f350sd
If the hubs are locked then you ain't in 2wd.
Correct! if all is working the way it should axles and driveshaft shouldn't turn in 2wd.
Old Aug 11, 2013 | 12:39 AM
Kdr358's Avatar
Kdr358
I also will contact warn on Monday and see about my warranty on the hubs, I read that if the springs are worn out it can cause a similar issue.
Old Aug 11, 2013 | 09:18 AM
EXv10's Avatar
EXv10
My hubs are locked all winter while I am in 2WD. (2 wheels driving).
Old Aug 11, 2013 | 12:49 PM
99f350sd's Avatar
99f350sd
Mine to! You know what I meant.
MurderMode
Oct 31, 2013 02:52 PM
drumdude
May 14, 2012 04:17 PM
AngryPossum
1978 - 1996 Big Bronco
Aug 30, 2010 01:31 PM
Manwith3fords
Feb 9, 2008 03:48 PM
