Won't start.
Old Aug 17, 2013 | 08:50 AM
bashby's Avatar
bashby
On the clutch switch, which is right above the gas pedal, there will be several wires. The ones for the start circuit are red with a blue stripe. Jumping the 2 of them will bypass the switch. You should have power to one of them when you turn the ignition to start.
Old Aug 19, 2013 | 11:44 AM
90'F150's Avatar
90'F150
I think I found it but I grabbed everything that I unplugged to take out the dash and pluged it back in and didn't have anything for that plug. Is there a like certain look to what plugs into it? If someone has a pic that'd help a ton.
Old Aug 19, 2013 | 12:16 PM
bashby's Avatar
bashby
Did you click the link in post 15? It has a picture. I just went out and looked at mine. The plug that would go to my clutch switch has 6 wires. The harness disappears up into the dash... I can see how it could have gotten folded up and lost if you had the dash out. I'm not sure if pulling the instrument cluster out would give you access or if you need to pull the dash back out.
Old Aug 19, 2013 | 02:06 PM
90'F150's Avatar
90'F150
Just saw that now and got. It fixed thanks for the help
JIM ROLAND
Sep 13, 2013 08:06 PM
49er_rs
1997 - 2003 F150
Nov 9, 2012 08:54 AM
wbhinton
Sep 5, 2006 10:40 PM
