Panel Body Removal
Old Aug 10, 2013 | 02:21 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Panel Body Removal
OK I know it's project creep but now that I've got the front of the frame semi cleaned and I'm thinking why not do the Whole Frame!!! Problem is I need to pick up the body to pull the frame out and get it cleaned and PORed.
Any of you guys got any ideas?? OBTW I'm just me. I can get my son-in-law to help if I have a plan but he's got kids, a job and a life other than helping dear old Dad
Old Aug 10, 2013 | 02:27 PM
Filthy1955F100's Avatar
Filthy1955F100
For our '55 cab removal, We got a real thick piece of square tubing probably 10 feet long, and put in an engine crane. We stuck ours in the back window with a D Loop with chains, and wrapped the chain around 4 braces, it bent the tubing but it got the job done. I can get you some pictures if you want?
Old Aug 10, 2013 | 02:33 PM
bjmayberry2
Would really appreciate pics if you got them.
Old Aug 10, 2013 | 02:56 PM
Filthy1955F100
On the doors there are steel brackets, how ever many of those there are, get that many chains, put the end of your chain in the d loop, then wrap it through the bracket and hook it back up the chain. You will probably have to have some people to stand on the crain because when it starts lifting it likes to lift the back off the ground.
It's kinda plain, but it worked just fine for us.
Old Aug 10, 2013 | 03:01 PM
bjmayberry2
Got it! Thanks
Old Aug 10, 2013 | 03:04 PM
bjmayberry2
Just realized something, are you removing a Cab or a Panel Body?
Old Aug 10, 2013 | 03:10 PM
Filthy1955F100
Mine was just a cab, but i think if you figured out exactly how, you could use the same concept.
Old Aug 10, 2013 | 03:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
BobJ had an animation of doing this a long long time ago. I'll see if I can find it...It's on his homepage: "'48 Ford panel truck"
Appears like it only take a minute or so...
Old Aug 10, 2013 | 03:25 PM
bjmayberry2
That's what I want to do but I don't have the forklift but it does give me some ideas. Looks like he picked up the front and back separately.
Old Aug 10, 2013 | 04:13 PM
DR Smith's Avatar
DR Smith
Are your rafters exposed in your garage? If so jack up all 4 corners of the truck,chain body to rafters and lower frame then pull frame out. My gallery shows how I did mine. I also made a steel table to sit the body on with casters to move it around.
Old Aug 10, 2013 | 04:24 PM
bjmayberry2
Thanks Dave, I'll check out your Gallery. Still looking for bar door hinges or Pinto Hinges.
Old Aug 10, 2013 | 04:52 PM
topmoo's Avatar
topmoo
When I built a woodie wagon body to put on the frame I used a small chain hoist hanging from my rafters and a rope at the other end. I lifted one end with the hoist then tied the body off, moved the hoist to another rafter near the back and lifted it. Then rolled the frame under and reversed the process. When I did my truck cab I built an A frame and used a small electric winch. I also used the A frame to lift my truck frame after I stripped it to paint. I did all these by myself, seems like help always came just a little too late...
The woodie just before I put it back on the frame, but you can see the chain hoist on the rafter. The woodie probably weighed about the same as your panel less the front clip. The second picture almost shows the A frame that I used for my truck. I had some galvanized pipe that a friend had left over from a job that worked fine and was free.
Old Aug 10, 2013 | 04:57 PM
bjmayberry2
Thanks for more input. Love the different ways folks here on FTE approach the same problem
Old Aug 10, 2013 | 11:56 PM
bobj49f2's Avatar
bobj49f2
I braced the back part of the panel first, then lifted the front.
It does help to have a forklift truck but there's other ways to lift it. I did the body swap in about four hours on a Sunday afternoon.
bjmayberry2
19
Jun 23, 2019 05:03 PM
Powerhour
1947 and Older Ford Trucks
40
Jan 21, 2019 02:24 AM
ttpenman
Sep 12, 2007 01:32 PM
teds74ford
General Automotive Discussion
22
Aug 23, 2004 09:33 PM
utvol1984
Paint & Bodywork
Mar 5, 2003 09:59 PM
