Firewall Access Point
Old Aug 10, 2013 | 09:22 AM
Force21's Avatar
Force21
Hi All,
Slowly moving ahead in this project. Just looked under the hood ("00 Limited 4x4, 7.3) for an access point thru the firewall to pull the switch wires thru and didn't readily find any. Is there am access point already? Or, do I, and it hurts me to even think this . . .drill . . .
Thanks again for all your advice.
Angelo
Old Aug 10, 2013 | 09:29 AM
TexasBeachBum's Avatar
TexasBeachBum
I really don't know about the 7.3 but on my 6.0 there is one right on the drivers side. Look under your dash and follow the wire bundles, it should be pretty obvious.
Good luck.
Old Aug 10, 2013 | 09:53 AM
Force21's Avatar
Force21
Good luck.
DUH.... Thanks Texas Beach Bum!!!! Funny thing is I saw that big wire bundle too but did not think more about it. I really should wake up before posting questions (hahahaha).
Old Aug 10, 2013 | 11:33 AM
housedad's Avatar
housedad
I found and used the 2 inch hole in the firewall above and left of the brake pedal way up under the dash. It is the mounting hole for a clutch pedal. The factory just has a very durable tape covering the hole. You can see the hole from the engine compartment easily. Just look for the tape.
There are two smaller holes next to it for bolts to go through that you could use too, if you only have a couple of wires. Use a grommet and sealant.
I made an adaptor plate and installed a 32 pin bulkhead connector there. Sealed watertight.
Old Aug 10, 2013 | 12:25 PM
Force21's Avatar
Force21
Woo Hoo! Thanks Housedad. I cannot wait to get out the truck again to check on this. Thanks for the pointers!
Angelo
Old Aug 10, 2013 | 02:13 PM
Archion's Avatar
Archion
Veteran: Marine Corps
And depending on what you are running, the are 4 pass through wires already.
th67ss
Sep 14, 2012 12:29 PM
housedad
Oct 6, 2011 11:01 AM
SHOpar
Aug 12, 2010 08:56 AM
357fhp
Jan 22, 2007 08:13 PM
ricepaddydaddy
May 17, 2004 06:19 PM
