Access Through Firewall
Old Aug 11, 2010 | 11:42 PM
SHOpar's Avatar
SHOpar
I'm getting ready to order up a MaxBrake hydraulic over electric brake controller for my truck within the next couple of days. Since the install requires a wire to be run through the firewall between the pressure sensor that is installed on one of the brake lines off the master cylinder and the controller itself, I thought I'd take a look under the dash to figure out the best way to run it.
I spent a good twenty minutes looking under the driver's side dash and hood, but I couldn't find any easy access that was obvious. I know the previous owner had a CB antenna mounted on the front fender, so I'm sure he found a way through, but I'm completely stumped. At some point I would also like to add a gauge pod, so know I'm going to have to find or make a way eventually.
Where do you all run your auxillary wires, antennas, etc. that have to pass through the from the cab to the engine bay?
Any ideas will be appreciated!
Thanks!
Old Aug 12, 2010 | 05:48 AM
FARM69's Avatar
FARM69
There should be a couple of holes in the firewall on the driverside. They may still have the rubber gourment in them.
Old Aug 12, 2010 | 08:50 AM
mojoman's Avatar
mojoman
I'd look at the firewall from the engine compartment to find access...too much crap under the dash to see much at all...from the engine compartment you should be able to easily see any access to the cab....hth
mojo
Old Aug 12, 2010 | 08:56 AM
superduty4x4's Avatar
superduty4x4
Guys like me with autos usually drill holes in the block-off plate from where the clutch stuff goes through the firewall. You really need to just stick your head under the hood and find a spot you can access with a drill, drill a hole and use a grommet to keep water from getting in the cab.
Spaznaut
Nov 29, 2016 07:31 PM
pacnorwest
6.7L Power Stroke Diesel
Aug 27, 2016 08:55 PM
johnNcarolyn
Mar 6, 2010 04:00 PM
Kraut
34
Jan 15, 2006 03:57 PM
linux_author
2004 - 2008 F150
15
Oct 14, 2004 11:11 PM
