E4OD shifting problems
Old Aug 13, 2013 | 02:03 PM
strokinout's Avatar
strokinout
Okay, now that finals are over I'll try to get some time to pull the codes today and let you know what I come up with.
Old Aug 15, 2013 | 04:10 PM
daddylee100's Avatar
daddylee100
check fluid, but need to pull codes to figure it out.
Old Aug 19, 2013 | 07:29 PM
strokinout's Avatar
strokinout
Okay, here's my codes. 53, 95, 39, 33, 44, 52, 33, 44, 53. Not sure why I got the a couple ones twice.
Old Aug 19, 2013 | 07:43 PM
rla2005's Avatar
rla2005
If the truck in your signature is the one with the problem it will display three digit codes.
The codes will display twice for each set, i.e. KOEO tests and for CM.
Old Aug 19, 2013 | 07:48 PM
strokinout's Avatar
strokinout
codes are 539, 334, 452.
539: A/C or Defroster ON during KOEO test
334: DPFE or EVP circuit above the closed limit of 0.67 volts.
452: Computer detected an error in the VSS or PSOM signal during the last 80 warm-up cycles.
Old Aug 19, 2013 | 07:54 PM
rla2005's Avatar
rla2005
Code 539 (KOEO): A/C or Defroster ON during KOEO test
Code 452 (CM): Computer detected an error in the VSS or PSOM signal during the last 80 warm-up cycles.
Code 334 (KOEO, CM, KOER): EVP circuit above the closed limit of 0.67 volts.
Your transmission issue is most likely caused by Code 452. Check the VSS sensor in the rear axle. Remove it, inspect for signs of debris/thick grease/etc. Clean it then re-install. Clear the codes then drive the truck again. If there are signs damage then you have a bigger issue to deal with. One step at a time.
You can check the output with a DVM: http://www.supermotors.net/registry/media/95932_1
Blindly replacing the VSS usually results in a lighter wallet.
Old Aug 19, 2013 | 09:01 PM
strokinout's Avatar
strokinout
I'll clean it tomorrow after my clinical and let you know what happens.
Old Sep 13, 2013 | 04:41 PM
strokinout's Avatar
strokinout
Wow, time flies by. I didn't realize it had already been almost a month since my last post in this thread. I need to send out a big thanks. I cleaned the vss sensor and all has been well...except for the a/c. About the second time I was having a severe shifting problem, I was running pretty high rpms as I couldn't shift out of second and the speed limit was 50. I kept hearing a whine out from underneath my hood that would come for a few seconds and then disappear for a few seconds. Then the whine came and stayed but when it did, my a/c got warm quick. I went through two recharging cans of freon and my a/c will stay cold for two, maybe three days afterward and then go warm again. Is there anyone here good with a/c as I'm only remotely familiar with the systems.
Old Sep 14, 2013 | 06:43 AM
barnym17's Avatar
barnym17
You've got a leak, gotta locate I, look for telltale signs of compressor oil on all the lines, condenser and around the compressor.
Old Sep 14, 2013 | 11:39 AM
strokinout's Avatar
strokinout
I already have and can't find anything. I tried to listen for any hissing also but the smog pump pulley bearing is too loud to hear anything.
Old Sep 18, 2013 | 06:09 PM
strokinout's Avatar
strokinout
Alright, well I spoke too soon. The transmission started acting up again today. I'm gonna replace the vss sensor and see where that gets me. But I'm still stumped about the a/c though. Does anybody have an idea what might have went bad in the a/c?
Old Sep 21, 2013 | 11:03 AM
strokinout's Avatar
strokinout
Nobody has any idea?
Old Oct 25, 2013 | 08:31 AM
  #28
mrrish79's Avatar
mrrish79
got nothing on the AC but how is the transmission after replacing the VSS? I'm experiencing problems and replaced the VSS but its still shifting hard and the overdrive "off" button is still flashing. I just bought a TRS and am going to install it, as well as do a transmission fluid change.
Old Oct 25, 2013 | 09:59 AM
  #29
strokinout's Avatar
strokinout
Well, not so good. The transmission only seems to do the hard shift, torque converter disengage thing when it's hot, but it has done it when cold as well. It doesn't flash the o/d light every time though which is weird. My abs light started coming on as of late but not when the transmission is acting up. I just changed the fluid with mercon v at 16 quarts and when I got done changing the fluid, I left the house to go to the junk yard and got about ten minutes of driving in and it started acting up and had to baby it to get to the junk yard. I ended up finding a small block 4x4 zf5 while I was there for $125. Talk about God smiling down on me that day. I'm surfing around on fullsizebronco's tech section now trying to find other things I can do till I finish getting the parts together.
IJRoorda
Jul 21, 2011 08:18 AM
djbeck88
17
Feb 2, 2011 05:00 PM
motoman
Feb 20, 2007 09:12 PM
RichPSD
Jan 24, 2006 08:09 AM
myvan
Aerostar
Jul 13, 2003 07:35 PM
