E250 2003 speedometer problem
Old Aug 8, 2013 | 02:59 PM
Tom2003's Avatar
Tom2003
Need help. 2003 E250 van battery went bad and speedometer quit working. Cannot find out why. Is the speedometer just bad or is it something else? Thanks for any and all help.
Old Aug 10, 2013 | 06:01 AM
JWA's Avatar
JWA
Is it still shifting as it should?
Does the odometer work or has it too failed?
Old Aug 11, 2013 | 08:58 AM
Tom2003's Avatar
Tom2003
the odometer is working ok just the speedometer has stopped.
Old Aug 11, 2013 | 10:01 AM
JWA's Avatar
JWA
I had asked if the trans is shifting properly too but here's an idea or two....
Most likely your cluster has failed and the easiest fix would be complete replacement. These are very year specific; if you go this route make sure you use cluster intended for your year and engine. Here's a good one: http://www.ebay.com/itm/2003-FORD-E250-VAN-79005-MILES-SPEEDOMETER-INSTRUMENT-CLUSTER-GAUGES-2604969-/271246779845?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2003%7CModel%3AE-250&hash=item3f279165c5&vxp=mtre
If you're more adventurous here's a post I made about the pre-digital clusters, it would help you maybe replace just the speedometer portion if you're so inclined: https://www.ford-trucks.com/forums/1...l#post11747876
Hope this helps!
Old Aug 11, 2013 | 11:48 AM
Tom2003's Avatar
Tom2003
Most likely your cluster has failed and the easiest fix would be complete replacement. These are very year specific; if you go this route make sure you use cluster intended for your year and engine. Here's a good one: eBay]2003 Ford E250 Van 79005 Miles Speedometer Instrument Cluster Gauges 2604969 | eBay
Hope this helps!
The transmission is working properly, no problems other than the speedometer stopped only after the darn battery quit. Replaced battery, no speedometer. I am fimiliar with the clusters as my chevy truck cluster had to be replaced which I did with no problems, took about 20 minutes.
Appreciate your help thanks Tom
jamien2
19
Jul 21, 2017 02:19 PM
69WestCoastFord
S. California Chapter
Jan 26, 2009 09:36 PM
92customvan
May 12, 2003 05:11 PM
lmdew
Feb 18, 2003 09:45 PM
LiteTrader
Electrical Systems/Wiring
Jan 11, 2002 10:58 AM
