I'm shooting for somewhere around 9.5:1, which is what my Silvolite 1130's are rated at. I just want to check it with this calculator. But, I'm having trouble coming up with the exact numbers that the calculator is asking for.
Bore: 4.352 (.30 over)
Stroke: 3.784
Cylinder Head Volume: 66 cc (D2FE stock heads, is this correct?)
Effective Dome Volume: (does anyone know for 1130's at .030 over?)
Deck Clearance: Can't get this number yet? It is a stock D4TE block.
Compressed Gasket Thickness: .037 (This is what the machine shop says for the Victor gasket set they sold me)
The numbers I'm not sure of is the Cylinder Head Volume, Dome Volume and Deck Clearance. Anyone know what these numbers would be? I know I won't be able to get exact Deck Clearance til I install the Crank and Pistons.
Yeah, I definitely considered the 1131's but didn't go with those because I didn't want to have to run Premium fuel. I am definitely considering the thinner metal gaskets (.014) to bring it to 9.73:1. Do you have to run premium fuel with 10.1:1?
I came up with 9.5 to 1 also, same as Silvolite advertises. I would not use thinner gaskets, if you're talking about steel shims. They don't tolerate overheating well. I've run two 10 to 1 390's on 87-89 octane. It's all in the cam. Last one had a Crane 272* Energizer, it was fine with 89 octane. The one before that had a Cam Dynamics grind (no longer around, this was in the early 80's) with specs of .516 lift, 290 something advertised duration, it ran on anything you fed it.
A mechanic told me that I have 78cc head volume. That puts my compression ratio around 8.5:1. That kind of bums me out, cause I was thinking around 9.25:1 with 66cc. The engine is already assembled and back in the truck (haven't hook everything up and started it yet.) Is there any way to get the exact cc for these heads? They are D2TEAA.
D2s are supposed to be around 68 stock. How did he get them to 78? Did work on them a bit, and remove material from the chamber...
He didn't actually work on the heads. He just looked it up in a book he had, but the part numbers weren't exact. He's a friend of a friend just trying to do a favor. So, I'm hoping he's wrong about that. I like 68cc much better. He did seem pretty knowledgeable about these engines and these trucks as he has worked on many.
Other than that, I just hand lapped the valves. New exhaust valves. Guides weren't in terrible shape and I didn't want to put another grand into the rebuild. There was slight play which will mostly go away when there's oil on them. When I have extra money, I'll redo the heads down the road. I'm already about $3k into this motor, for a truck that I paid $1900 for. But, I'll have a pretty nice truck when I'm done.
