Compression Ratio
Old Mar 26, 2006 | 02:21 PM
fishin machine's Avatar
fishin machine
Compression Ratio
What king of CR am I gonna get with this set-up. What I come up with doesn't seem right.
Stock block .040 over
61cc heads
Comp Cams 35-255-5
Old Mar 26, 2006 | 02:58 PM
petes79f150's Avatar
petes79f150
The cam doesn't have anything to do with it.
CR=Cyl.Volume @ BDC/ Cyl.Volume @ TDC
CV=Clearance Volume
CR=(CV+Swept Volume)/CV
CR=1+ Swept Volume/CV
CR=1+ (Swept Volume/Vol@TDC)
CR=1+ (0.7854 X Bore X Bore X Stroke)/ (CCV + HGV + PDV)
Note: If volume is given in cc's then / by 16.4 to get cubic inches.
HGV= Head Gasket Volume, in cubic inches
HGV= Head gasket compressed thickness X 0.7854 X bore X bore
PDV= (0.7854 X bore X bore X deck to piston distance)+ (volume of piston depressions - volume of piston bumps)
CV= CCV + HCV + PDV
Example: What is the CR of the engine if heads have 72 cc chamber, head gasket is compressed to 0.040 inch and flat top pistons give 0.025 deck clearance @ TDC?
CCV= 72/ 16.4= 4.39 cubic inches
HGV= 0.040 X 0.7854 X 4.030 X 4.030= 0.51 c.i.
PDV= 0.025 X 0.7854 X 4.030 X 4.030 / (4.39 + 0.51 + 0.32)
CR= 1+ (0.7854 X 4.030 X 4.030 X 3.48/ ($.39 + 0.51 + 0.32)= 1 + (44.39/ 5.22)= 9.5cr.
Did that help?
Old Mar 26, 2006 | 03:14 PM
baddad457's Avatar
baddad457
The cam has an effect on the dynamic ratio, but not the static ratio. If your engine now has a 9.0 to 1 ratio ( static) with 64cc heads, going with a .040 overbore and less 3cc heads will only raise it at best, 1/2 point to 9.5 to 1. Of course this is assuming the 40 over pistons have the same deck clearance the stock pistons had. Many don't. Pin heights range from 1.585 to 1.610 for 5.0/302's. The shorter the piston, the less compression it'll have.
Old Mar 26, 2006 | 03:25 PM
petes79f150
Nice catch, baddad. I forgot to get into piston variables.-P.
Old Mar 26, 2006 | 04:00 PM
baddad457's Avatar
baddad457
The piston heights are where many get into trouble with 302 comp ratios. And it gets worse with 289's, they use the same pistons.
dannyb 73
New Member Introductions
Mar 1, 2014 01:50 PM
nightrain04
Feb 2, 2008 11:31 AM
winston chopper
Jan 20, 2007 01:08 PM
Roach2004
Nov 19, 2004 11:08 AM
chucknc
Aerostar
Oct 21, 2003 08:32 PM
