Steering box interchange?
Old Aug 7, 2013 | 11:23 AM
stephen.osborne1's Avatar
stephen.osborne1
Can anyone tell me which years/models the steering box is interchangeable with? My daughter has a '92 f-150 4x4, and her steering has a LOT of play in it, so I was hoping to find a new one in a junk yard. Are all 87-96 F-series the same? Broncos? Thanks.
Old Aug 7, 2013 | 12:13 PM
quaddriver's Avatar
quaddriver
when I did my 1981 F100 I found that the same PS box is used from 80 (or older) to 96 (or perhaps newer), however, I also found that you must use the bolts that are on your box if you switch from the 87-96 generation to the 80-86 cuz the 80's frame is narrower there.
Old Aug 7, 2013 | 05:49 PM
stephen.osborne1
Very cool... Shouldn't be any trouble finding one in a junk yard... Also, do you know if 4x4 and 4x2 boxes are the same too? I know I can just look for part numbers, but I haven't taken the old one out yet, and its pretty greasy and cannot read (or find) the number. Thanks again!
Old Aug 7, 2013 | 06:16 PM
Diesel_Brad's Avatar
Diesel_Brad
80-mid 97
ranger, bronco, f150, f250, f350,F-superduty 2wd or 4wd are all the same
Late 97 they changed the box
Old Aug 7, 2013 | 07:39 PM
Encho's Avatar
Encho
The Southernmost Mod
Actually this unit has been used in different cars/trucks since 1964, but for the sake of interchangeability you should go with F-series from the 80-96 vintages. There are several E-series that should interchange too, I'm sure.
jamhh
Apr 26, 2013 09:33 PM
SuperDuty93
Apr 23, 2012 11:24 PM
mustange70
Offroad & 4x4
Dec 11, 2005 02:13 AM
Lone Wolf #2
Nov 18, 2005 10:46 PM
Jason 88F150
May 9, 2002 06:38 PM
