Temp gauge
If you want actual numbers, you have to install an aftermarket gauge. The stock gauge is too inaccurate to correlate to solid numbers. It's really meant as a relative go/no-go warning indicator. If someone really wanted to figure it out, they could test that, but I wouldn't trust it to be the same from truck to truck.
Now that I have a mechanical temp guage and can compare it to the stock guage I am thinking to myself why do I need the mechanical guage now that I know what the temps translate to on the factory one. It moves just as well as the mechanical one.
Agree the stock gauges are not super accurate or consistent. That said, with a 192 (factory) stat, normal temp will be about 195-200. Mine is about in the middle of the range in normal operation.
Pressurized coolant won't boil until about 250 F. I'll guess Hot is in the 230-240 range.
BIGskinny
May 19, 2011 11:18 PM
