Sponsored by: Auxito
pats anti theft
Old Aug 7, 2013 | 05:49 AM
99F250LDEXTCAB's Avatar
99F250LDEXTCAB
pats anti theft
i recently rolled my 99 f250 ld and i losted the only key since, now i have a 2001 f150 cab i am puttin on the frame because there was only cab damage, the 2001 f150 has the 4.6 in it so i went an got the instrament cluster, key an ingnition key tumbler and ecu out of another 2001 with the 5.4, i am currently in the process of switching the cabs over, is there anything else i would need to make this run when its done beside the ecu, cluster, and key to match ?
Old Aug 7, 2013 | 05:36 PM
steve(ill)'s Avatar
steve(ill)
If everything is out of the same truck, i think your o.k. If some thing is not matched then you will be going to a dealer to have the computer reset.
Old Aug 7, 2013 | 08:56 PM
99F250LDEXTCAB
yes
yes the key an key tumber, an instrament panel an ecu are from the same truck with a 5.4, is that all i need for pats to work an start my truck almost crunch time to turn the key
jcaspersnow
1997 - 2003 F150
Mar 13, 2011 08:26 AM
JF94
1997 - 2003 F150
Aug 19, 2010 06:35 AM
TJ Shaw
13
May 26, 2007 05:58 PM
Doorgunner808
1997 - 2003 F150
Mar 12, 2004 09:04 PM
