6.0L sputters in same location - Bermuda Triangle?
Old 08-06-2013, 09:53 AM
spikedog's Avatar
spikedog
spikedog is offline
I've had a 2007 Coachman Freelander class C RV with E-450 for about 8 months now. We have been on 7 camping trips to the same location this summer, and the engine has sputtered in exactly the same place on 6 of these trips. It's pretty freaky, like the road has bad mojo there.
We have to come down a steep incline for about 2 miles, dropping about 500' vertical at about 6500' elevation. Then we drive for 2 miles on the flat before hitting a big mountain climb up to 7500'. About 30 seconds into the climb, the engine will sputter, and kick out smoke from the tailpipe. The first time I pulled over, and it idled fine. I took off and climbed the hill just fine. Now I just drive through the sputter, and it goes away after a minute.
So what's happening? Is the fuel tank sloshing crud around? I never get a water-in-fuel alarm, although the E450 doesn't have much of a message center. It doesn't happen on other sections of mountain road. This rig has about 38,000 miles, and is bone stock. I put new oil and fuel filters in before the summer. This rig is the same size as my old '82 RV E350 w/ 460, and boy is the 6.0L an improvement!
Old 08-06-2013, 11:17 AM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
It doesn't do the sputter on any of the other climbs you encounter?
Josh
Old 08-06-2013, 11:23 AM
BLADE35's Avatar
BLADE35
BLADE35 is offline
f 450 and F 550 Had fuel tank delamination problems
so if truck starts to cut out at a really steep part in the road might have something to do with that feel pick up tube be getting clogged
spikedog's Avatar
spikedog
spikedog is offline
No, it grunts right up other hills like a champ.
It happens when the tank is full or when it's half full too.
Old 08-06-2013, 04:10 PM
Restlesswildman's Avatar
Restlesswildman
Restlesswildman is offline
How are you on the pedal? Are you nice and steady or are you mashing it like a gasser when it stumbles??
What color smoke are you seeing out of the tailpipe?
Old 08-06-2013, 04:45 PM
spikedog's Avatar
spikedog
spikedog is offline
It's an RV. Much like a Harley, mashing the throttle only makes things louder, not faster.
The downhill before the uphill is the only place where I'll downshift a couple of gears and engine brake significantly. Most of the other hills I can just coast down, maybe tap the brake a little.
I think the smoke is black, but it's just in spurts. Not like its a big cloud.
Old 08-06-2013, 04:56 PM
Restlesswildman
Have you pulled your EGR Valve and cleaned it?
Do you have a SG 2 or any other data monitor hooked up ?
You need to see what the DATA is when this happens
Old 08-06-2013, 05:16 PM
spikedog's Avatar
spikedog
spikedog is offline
I see a link to a scangaugeII for $112 at AdvanceAuto
on another post in the 6.0L forum. I've been looking at Edge Insights & various Bullydogs, but they don't seem to be geared to the vans, only the trucks. I even called the Edge folks, they said naw, don't put the Insight on your E450. The ScangaugeII looks like it might do what I need, with the exception perhaps of the exhaust gas temp and some cooling system delta T's.
Old 08-06-2013, 05:24 PM
Restlesswildman
A guy I work with has an edge insight. I was having issues with the EX and he hooked his Insight up to the Ex. It is a lot nicer looking then the SG 2 and has a few features that the SG 2 does not. The main one was the EGT monitoring.
The down side to the Insight is cost. If you shop around on Amazon and fleabay you might find a deal.
As far as the EGT probes you need to research the various types of probes. My cow worker wired his up a way i never saw before. But then again I have only seen 2 trucks with EGT monitoring.
The Delta T's are just the spread between the EOT and ECT.
Old 08-06-2013, 05:36 PM
Bullitt390's Avatar
Bullitt390
I wouldn't run a tune on an RV.
DashBoss would be a good monitoring tool as you can record as you drive and log what is going on and really get into detail T what was causing the sputtering.
Josh
Old 08-06-2013, 05:57 PM
spikedog's Avatar
spikedog
spikedog is offline
I have no intention of running a tune on this. I've got so many other things that can go wrong on this rig (generator, furnace, water pump, holding tanks, etc) that I try to keep it simple. Quite happy with the amount of grunt; the mileage I'm getting (~10 mpg) is a pleasant surprise too.
Old 08-06-2013, 06:24 PM
04badford's Avatar
04badford
04badford is offline
This is true and you should check fuel pressure and put the Blue spring in to make sure.
Old 08-06-2013, 08:15 PM
cheezit's Avatar
cheezit
cheezit is offline
got a metal fuel tank in it?
Old 08-06-2013, 09:16 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
One odd question.
Did that rig have an OBD2 port or the other type?
When you go to ScanGauge - Trip Computer + Digitial Gauges + ScanTools
There is mention about this
ScanGaugeD works with J1939 & J1708 Protocol
Perfect for Diesel pusher RV’s and over the road, long-haul trucks.
and that could be a problem and is why I asked the question.
All that said it would be good to see some live data when it sputtering.
It would also be a good idea to have a look inside the tank.
Sean
Old 08-07-2013, 08:40 AM
spikedog's Avatar
spikedog
spikedog is offline
It's got an OBDII port. I plugged in my old reader when I was test driving it before purchase and didn't get any codes.
Not sure what the tank material of construction is. I do know that it takes forever to top it off due to foam (don't want to bayonet it).
Quick Reply: 6.0L sputters in same location - Bermuda Triangle?
