sputtering under load
Old Aug 5, 2013 | 12:36 PM
Schickel's Avatar
Schickel
Hey guys I got a 1977 f250 with a 400 and manual transmission, I use it as my pull truck and as I go down the track it sputters something awful. Im told and ignition system would fix this but what do you guys think of this?
Old Aug 5, 2013 | 06:24 PM
MeanGreen460's Avatar
MeanGreen460
Could be a number of things .Coil Ignition module Carburator problem getting too much or too little gas .I would check timing first then vaccuum advance pull check spark plugs see if its running lean or rich .then check fuel pressure then carb. Need a little more detailon what carb your running and if the engine is stock or cammed up
Old Aug 6, 2013 | 10:23 AM
Schickel's Avatar
Schickel
Im running a 650 double pumper holley on top of a 2" carb spacer with ported heads with a moderate cam and headers
HVACTOM
94
Sep 27, 2015 01:26 PM
bamafarmboy
Sep 15, 2013 06:48 AM
53fatfndr
Aug 26, 2004 10:55 PM
cjcathey2002
Oct 17, 2002 12:23 PM
jaye
Nov 12, 2000 04:02 AM
