78 Ignition timing
Old Aug 4, 2013 | 08:36 PM
1979 300i6's Avatar
1979 300i6
78 Ignition timing
I recently purchased a 1978 Ford F150 351 modified that was rebuilt but sit 2 years withought ever being started or with any oil, the Distributor was just put in and Since it never ran it Was never put into time, I got the Engine cranking over good, But it will only hit a little bit and backfire so i figured its way out of time, the Disturber is as far right as it will go (when sitting in truck) any one have an idea where I should have the Distributor sit at starting out?
Old Aug 4, 2013 | 09:03 PM
march's Avatar
march
Ok, I'll give this a shot, but there is lots of info on the web to help.
Do you know what the initial timing should be? Pick the one that fits from this list.
<table width="580" bgcolor="#cccccc" cols="3" border="1" cellspacing="2" cellpadding="7"><tbody><tr><td width="25%" align="left" valign="top">F150/250/350
</td><td width="50%" align="left" valign="top"> 351M, auto trans
</td><td width="25%" align="left" valign="top"> 14° BTDC
</td></tr><tr><td width="25%" align="left" valign="top"> F150/250/350
</td><td width="50%" align="left" valign="top"> 351M, auto trans, CA emissions
</td><td width="25%" align="left" valign="top"> 8° BTDC
</td><td width="50%" align="left" valign="top"> 351M, manual trans, CA and 49-state
</td><td width="25%" align="left" valign="top"> 6° BTDC
</td></tr></tbody></table>
Rotate the engine by hand until the timing indicator is on the correct initial timing. Then make sure the rotor is pointing at the number 1 cylinder (if it's 180 out that's ok). Then rotate the distributor until a prong on the reluctor lines up with the magnet in the pickup coil. This should get you close enough to get it started.
Old Aug 4, 2013 | 09:16 PM
1979 300i6's Avatar
1979 300i6
Thanks a lot I'll give it a shoot
Old Aug 5, 2013 | 03:10 PM
1979 300i6's Avatar
1979 300i6
I can't seem to find the timing pointer anyone one have a picture of where it should be?
Old Aug 5, 2013 | 06:16 PM
MeanGreen460's Avatar
MeanGreen460
How is the compression ?If its been sitting 2 yrs the cylinders may be dry not making much compression .I;d pull the plugs out and shoot some Wd 40 or a little oil in the cylinders crank her over with plugs out then reinstall plugs. Make sure your distributor is wired right .You may want to turn distributor advance or retard while trying to start it .
Old Aug 5, 2013 | 08:15 PM
march's Avatar
march
Old Aug 5, 2013 | 09:08 PM
J ballan's Avatar
J ballan
March
Me
I will disagree with this ^.Trying to set your ingnition timing with the engine 180 out is a bad idea. You need to rotate your engine until it is on top dead center on the compression stroke, then drop the distributor in with the rotor pointing to #1cylnder on the cap. This should be close enough to start it. Then using a timing light and the timing marks on the balancer set it to whatever is recommended for your engine (assuming its stock) with the vacume advance unhooked. Good luck.
Old Aug 5, 2013 | 10:36 PM
march's Avatar
march
J is correct. I was assuming that the distributor was installed "close". If my process doesn't work, you'll need to do as J suggests. Let us know if your unsure of how to find TDC of the compression stroke.
Old Aug 5, 2013 | 10:42 PM
1979 300i6's Avatar
1979 300i6
Thanks for all the replys, march, yes I am pretty new to this and help on how to find the tdc would be greatly Appreciated
Old Aug 5, 2013 | 11:04 PM
march's Avatar
march
Assuming you balancer was installed correctly TDC is marked on it. To make sure your on the compression stroke, remove the #1 spark plug and rotate the engine until you feel pressure on your thumb. That's the compression stroke. TDC is at the top of this stroke.
Old Aug 6, 2013 | 11:36 AM
1979 300i6's Avatar
1979 300i6
Ok, I have Follow the above about TDC and have found it, but I am now having trouble getting the dizzy to drop in with rotter facing Cylinder number 1, any suggestions
Old Aug 6, 2013 | 11:45 AM
J ballan's Avatar
J ballan
Sometimes they hang up on the oil pump driveshaft. Take a 3/8 socket and tape it to a long extension. Should be able to turn it a little and try again.
wcjones
Sep 4, 2015 06:57 AM
earthquake68
28
Mar 19, 2015 11:27 PM
cysneed
Dec 17, 2014 07:42 AM
blkempinc
Feb 14, 2010 08:30 AM
buzzer12
Oct 12, 2003 06:11 PM
